![]() | Home > Technical (L322) > suggestions for tow bar |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
Everything was with the kit, just plugs straight in. If you look at the instructions (linked from eBay site) it shows you what's included, and where to mount everything.
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
wish Id seen that comment before...my Westfalia kit turned up and had the towing ECU in it ....so my new OE Towing ECU is surplus now
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Now you lot are just confusing me !!
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Have a look here: http://www.pfjones.co.uk/tow-bars/tow-bars...wbars.html
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Westfalia is the oem fitted by land rover. They make the metal bits and the wiring kit, fits as intended with all the extras. http://www.westfalia-automotive.de/index.php?id=home&L=1 search here for the stuff will have fitting instructions in pdf for you to look at, then order from the cheapest source - Towequipe, Pfjones, e-bay, etc. |
yes, got mine from PFjones - westfalia OE dedicated plug play kit for FFRR
