![]() | Home > In Car Electronics (L322) > Aux socket problems |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3958 ![]() ![]() ![]() |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Re shutting . Mine doesn't stay shut either. If you take the bottom left side vent by the rear passengers feet off (easy clips on/off) you can see the mechanism which is pretty flimsy. Mine clearly had a part of it snapped off when forced previously (presumably)?
Just use two well placed bits of velcro on the inside lip and it stays shut , anyone in the back is none the wiser |
Excellent thanks.
356pilot Member Since: 31 Dec 2010 Location: Peak District Posts: 16 ![]() ![]() ![]() |
Oh - also - while you've got that lower vent panel off, there are two larger torx screws which become visible (one on each side) which I believe would probably allow you to remove the whole rear panel and get at the lid mechanism. Haven't tested that theory though. |
I'll post again before I start the work then if I get stuck in the car and no ones heard from me after a few days Martin can organise a rescue party |
Was wondering where you had gone Geoff. Sorry to hear about your job. Present :2008 TDV8 HSE
Job Done |
Excellent! Love it when a plan comes together.... |
