![]() | Home > In Car Electronics (L322) > No Sound - Newbie |
Have you checked for water ingress? |
pandar Member Since: 02 Nov 2011 Location: Sheffield Posts: 6 ![]() ![]() ![]() |
Hello 47p2
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Might be a loose plug. When I fitted in my freeview reciever, I had a few issues like no sound, blank screen etc. I went through the compartment and undid every plug and plugged them back in.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Just because it's dry at the moment doesn't mean it has been for the last 7 years. |
Hello nicedayforit/Reformed
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
I would recommend a special oxide remover such as Wurth Contact OL
Thank you for your tips gentlemen
Should be 4 boxes in the rear compartment as below, you appear to have the tv tuner missing or the radio tuner missing. Lets know which.
Good grief, how embarassing. |
You really need to remove the black plastic panel below the carpeted floor panel.
Right....................I accessed the radio tuner box and took it out. It appears dry and the connector had no sign of corrosion. I then shorted the two battery connectors together (again) just in case this brought the dsp back to life.
Before you resort to buying an amp you may wish to consider this.
