Home > In Car Electronics (L322) > No Sound - Newbie |
Have you checked for water ingress? |
11th Jan 2012 7:14pm |
pandar Member Since: 02 Nov 2011 Location: Sheffield Posts: 6 |
Hello 47p2
11th Jan 2012 7:40pm |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
Might be a loose plug. When I fitted in my freeview reciever, I had a few issues like no sound, blank screen etc. I went through the compartment and undid every plug and plugged them back in.
11th Jan 2012 7:48pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Just because it's dry at the moment doesn't mean it has been for the last 7 years.
11th Jan 2012 7:51pm |
Hello nicedayforit/Reformed
11th Jan 2012 9:55pm |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
I would recommend a special oxide remover such as Wurth Contact OL
12th Jan 2012 10:12am |
Thank you for your tips gentlemen
19th Jan 2012 4:10pm |
Should be 4 boxes in the rear compartment as below, you appear to have the tv tuner missing or the radio tuner missing. Lets know which.
19th Jan 2012 5:06pm |
Good grief, how embarassing.
19th Jan 2012 5:26pm |
You really need to remove the black plastic panel below the carpeted floor panel.
19th Jan 2012 5:33pm |
Right....................I accessed the radio tuner box and took it out. It appears dry and the connector had no sign of corrosion. I then shorted the two battery connectors together (again) just in case this brought the dsp back to life.
23rd Jan 2012 5:02pm |
Before you resort to buying an amp you may wish to consider this.
24th Jan 2012 2:28pm |
