Home > Maintenance & Mods (L322) > led upgrade
Page 5 of 9 <123456789>
bosch
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Crazyled do the complete kit of led for the interior, side lights and rear number plate 19 lamps and are canbus so no warning messages for £59.99. I have installed the kit and it looks great
Post #103243 24th Jan 2012 10:12am
jaybear
France
Bosch
here is the reply from Crazy Leds website
CrazyLed's :: RANGE ROVER
RANGE ROVER
There are no available products under this category.
Bookmark / Share Bookmark / Share
Add to Twitter
Jaybear Sad Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #103249 24th Jan 2012 11:03am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Has anyone got rid of the start up flicker from LED sidelights (low current bulb continuity checking) ?
Post #103256 24th Jan 2012 11:22am
i quite like the flicker and tbh i dont take much notice now.. ... - .- -.
Post #103260 24th Jan 2012 11:32am
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
There still doin the kits on eBay just found it myself
Item number: eBay Item No. 200525613731
Post #103267 24th Jan 2012 12:03pm
bosch
That is the same company and kit, they look good
Post #103268 24th Jan 2012 12:07pm
mjdronfield
anyone done the indicators ?
what would you need ?
thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #103509 25th Jan 2012 8:24pm
Checking for fog lights for an '02
These bulbs
http://www.ebay.co.uk/itm/H7-CREE-Q5-LED-F...519c012624
and these resistors
http://www.ebay.co.uk/itm/50W-3ohm-LOAD-RE...4156ba0e42
Yes ? .
Post #103825 27th Jan 2012 1:51am
daveo
with ref to the fog lamps ant the cree led's, yes they do look brighter and throw out a bit more light but the prob is you end up with a dot of light in the middle of the fog lamp as there is no angled light from the sides.
it depends what you want to use them for,if its DL then go led but if you want some light out of them then stick with halogen or pop a xenon kit in there.. V8 facelift Range Rover Autobiography 22" wheels.
Post #103844 27th Jan 2012 9:00am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Daveo many thanks for the guide, can I be cheeky and ask a question please? Can I buy some higher powered H7 bulbs for my main beam? If so what would you recommend? just want a lot brighter, whiter light if possible
Post #107329 14th Feb 2012 4:51pm
if i may but in, i measured the voltage on my mains and it was only reading 10 volts.....i can only think that because its only supplementary lighting its not getting the full whack...
fitting higher wattage [100w] bulbs might not get the desired effect.. ... - .- -.
Post #107375 14th Feb 2012 7:10pm
daveo
hi, i have tried led's they give the desired light,colour wise but they don't throw out much light, but as i live in London i don't need the output, saying that i have gone for a set of canbus free xenons 5000k they do give me the colour and the light output of a normal bulb..this gives you Tri-xenon as i like to call them.
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #107449 14th Feb 2012 11:54pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Led approach lamps
Hoping someone can point me in the right direction, I fitted LEDs inside and outside my RR and all is good except, I am having problems with the approach lamps on the wing mirrors as someone here mentioned they had too , one will work until the two are connected. I beleve Resistors are needed etc, but I have canbus LEDs, are these not built in resistors?
And weird thing is, even when I put the old bulbs back in I have to disconnect and reconnect battery to get them working again. Fuses are grand, turned bulbs around, doing head in as I have already broken the glass on one of them with frustration, they v finicky to get off Big Cry
Here are the LEDs I have put in them
http://www.ebay.co.uk/itm/220913850839?ssP...m1439.l264
Post #107975 18th Feb 2012 8:01pm
just a guess but try turning the bulbs around in the holder..might be different polarity's working against each other.. ... - .- -.
Post #107993 18th Feb 2012 9:59pm
daveo
hi, you dont need the can bus warning on these bulbs.. but i had the same problem when i changed my ones to leds, i solved it by using a resister on both sides to increase and even out the load.. V8 facelift Range Rover Autobiography 22" wheels.
Post #108014 19th Feb 2012 12:30am
