![]() | Home > Maintenance & Mods (L322) > led upgrade |
| jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156
Bosch
| VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380
Has anyone got rid of the start up flicker from LED sidelights (low current bulb continuity checking) ? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i quite like the flicker and tbh i dont take much notice now.. ... - .- -.
| cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556
There still doin the kits on eBay just found it myself
| bosch Member Since: 20 Jan 2012 Location: Kent Posts: 18
That is the same company and kit, they look good |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
anyone done the indicators ?
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Checking for fog lights for an '02
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
with ref to the fog lamps ant the cree led's, yes they do look brighter and throw out a bit more light but the prob is you end up with a dot of light in the middle of the fog lamp as there is no angled light from the sides.
| mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766
Daveo many thanks for the guide, can I be cheeky and ask a question please? Can I buy some higher powered H7 bulbs for my main beam? If so what would you recommend? just want a lot brighter, whiter light if possible |
if i may but in, i measured the voltage on my mains and it was only reading 10 volts.....i can only think that because its only supplementary lighting its not getting the full whack...
hi, i have tried led's they give the desired light,colour wise but they don't throw out much light, but as i live in London i don't need the output, saying that i have gone for a set of canbus free xenons 5000k they do give me the colour and the light output of a normal bulb..this gives you Tri-xenon as i like to call them.
| Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608
Hoping someone can point me in the right direction, I fitted LEDs inside and outside my RR and all is good except, I am having problems with the approach lamps on the wing mirrors as someone here mentioned they had too , one will work until the two are connected. I beleve Resistors are needed etc, but I have canbus LEDs, are these not built in resistors?
just a guess but try turning the bulbs around in the holder..might be different polarity's working against each other.. ... - .- -.
hi, you dont need the can bus warning on these bulbs.. but i had the same problem when i changed my ones to leds, i solved it by using a resister on both sides to increase and even out the load.. V8 facelift Range Rover Autobiography 22" wheels.
