![]() | Home > Maintenance & Mods (L322) > TD6 Transmission fluid |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 ![]() ![]() |
Hi,
No belt on TD6 its a chain so should last life time of engine cant comment on gearbox as I have a TDV8.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Have a read of this re gearbox
Thanks Guys, from reading that i think i'll get it done (the transmission, not the cam chain - bonus |
I've been quoted at a local auto box specialist £85 +vat and it would take 3hours for the work and just to bring it in warm so it drains more eaisly |
Genuine Land Rover filter and sump gasket will give no change from £100, and Texamatic 7045E will cost £15 per litre plus VAT. If you remove the gearbox sump plug you will only be able to drain around 4 litres of ATF at a time. Removing the sump and replacing the filter will allow around 7 litres of fluid to be changed.
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
Gents
There are a few places selling Texamatic 7045E at £65 for a 20 litre |
This is where I got my 20 litre drum from
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
I bought 20L of Texaco 7045E from Watsons Oil (Google them) for £66 delivered (including VAT) |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Treading very carefully here.
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Just as an addendum to this topic, I've been doing some research of my own and spoken to an ex-colleague of mine who works for BP in their lubrication division and he recommends Castrol Transmax Dextron III Multi-Vehicle. Reading the technical data sheets of both this and Texaco 7045 reveals very few differences, with the Castrol product being arguably superior. Unfortunately, it only appears to be available in 1 litre bottles over here at £10 a pop, so 7045 is still the better option, but if you can buy it in bulk elsewhere then I wouldn't think twice about it if it was cheaper. |
But you know what everyone here will say if you don't use Texamatic ETL-7045E and your back in three months with a gearbox problem |
Yep. |
