Home > Maintenance & Mods (L322) > Treadplate and A post lower finisher removal
Got to run some cabling from back to front believe the best route to be under the D post lower, under the rear retainer, B point lower, front retainer, A post lower, footwell closing panel to centre console.
See image
Don't have a trim removal tool, so what do I use? what type of clips are they.
For the A post lower finisher it says: "Check condition of finisher retaining clips in
body, replace if damaged"
which probably means they will break?
Anyone had experience of doing this? Or is there a better route? (headlining?)
Oh, note image from Rave showing manual seats? .
Post #103986 27th Jan 2012 7:31pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Not strictly correct so don;t tell anyone else on this forum but...
I used a nice big flat screw driver. Tuck it under the front edge carpet side and gently lever it upwards. the first clip should pop up and then work your way back. Takes seconds to do.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #103991 27th Jan 2012 7:58pm
In the past I've used a common or garden knife from the cuttlery drawer!
I used one that was a bit thicker and sturdy than those you'd get in Ikea etc, and it did a great job and doesn't tend to leave any marks on the panel being removed.
That being said, I bought a set of panel removel tools from Machine Mart for about a fiver! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #103992 27th Jan 2012 8:05pm
Vogue
I used a slim wooden salad fork handle, the type of rubbish you get for pennies from ikea, slim and doesnt damage trim - used it to fit power cable for a jammer (aka electric gate opener of course)
Post #104016 27th Jan 2012 10:55pm
Well I went at it today with a decorators palette knife, the type you would use to apply filler or scrape wallpaper off with. Worked a treat, and the tread plates pop off quite easily. The A post lower finisher more or less fell off after that, with one of the clips already broken.
As for my cable run, I had to remove the B post upper and lower covers and the finisher (the covers come off together, and you have to bend then outwards in the middle to split them apart and release the top fixings), the rear tread plate, the lower D post finisher, then ran the cable from the audio / tv gubbins corner, up over the wheel arch, down under the rear tread plate and tucked under the carpet, up past the B post but under the B post lower finisher, back under the carpet and the front tread plate, then into the cavity revealed by the A post lower finisher, dropped the footwell closer and ran the cable across the top of that.
My target is the coin tray in front of the gear lever, where I am fitting two push switches. This seems to be the only place where a) there is enough room below for the rear of the switches, b) a fairly straight forward cable run to it, c) accessible by both driver and passenger, d) least destructive - the two holes I will make can always be covered over with a piece of black plastic if returning car to normal.
Note: Rave says to disable the SRS if removing the B post, I presume this is only if you will be tackling the pre-tensioners on the seat belts. .
Post #104146 28th Jan 2012 7:01pm
tsadpt
If you can get your fingertips underneath, brute force works! Just pull it straight up. The tricky bit is getting the pins aligned Witt the holes when putting it back. The pins slide in a track on the underside of the tread plate, but there are little semi-circular notches in the track indicating where the pins should be. I use a little ball of blu-tak to stop each pin moving when I turn it the right way up.
Post #104167 28th Jan 2012 8:27pm
