Home > Maintenance & Mods (L322) > 2011 interior into a 2005 pre-facelift
Can it be done, are the mountings and connectors the same and so forth??
Just thinking as sometimes dirt cheap newer interiors come up on the bay from breakers and the like and think hmm i could give them a go at that price but then chicken out Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #105280 3rd Feb 2012 5:50pm
Reformed
Would be good if they can. Ive put the little silver Range Rover badge on the passenger side above the glovebox like the newer ones, so thats a start Thumbs Up Reformed
Post #105285 3rd Feb 2012 6:22pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Reformed is it like the 2011 badges??
Where did u get it from? What sort of price was it?
thanks
Neil
Post #105304 3rd Feb 2012 7:24pm
fisha
It probably would fit physically , but a lot of things spring to mind why it would be far from plug and play. All the console buttons work over a different protocols, the vents are different , so would that mean a different heater, do the coolant pipes run through the bulk head differently etc etc etc V8 or else ...
Post #105311 3rd Feb 2012 8:09pm
SteveMFr
Site Sponsor
Given time and money you can do anything. You'd have to change nearly everything, tho. The switchgear is different in great part so you'd have to transfer the old electronics to the new bits and what would you do with things like terrain response or the parking brake ? (you could purchase a 12v linear acutator and build your own e-brake... Razz ). But the biggest prob would be nearly all the airbags aside from the steering wheel airbag.
We had this discussion once before: Mattstevenson asked. I'd say def not worth it unless you have no life, too much money, and are looking for a challenge. About 7-8 years ago I saw a website dedicated to reprogramming a certain type of Kodak digital camera to play Pac Man on the rear screen. Maybe that guy has finished and is looking for something new...
Laughing
EDIT: you could buy a totaled 2011 with next to no damage to mechanical bits and such and rebody it with an early L322. But you'd need everything: all wiring, ecu's, motor, transmission, -everything. Still probably easier and less of a bodge than swapping just the interior, tho.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #105313 3rd Feb 2012 8:14pm
Vogue
check you haven't stuck it on top of the air bag - its in a different place to the 07my, just in case it goes off in an impact and your wife / girlfriend has a RR badge sticking out of her ear.
Post #105325 3rd Feb 2012 9:02pm
Reformed
I have mine at the top just above the SRS clip, where as on the newer ones its slightly lower. I used Microcat to track down the part number and then ordered it from Dan at duckworths.
On the newer ones its held in with to little pips at the back, so I trimed them of, filed it down so there was no sharp edges, and just used double sided trim tape (thinner 3m stuff) to stick it on.
I cant remember what I paid now, it wasnt a lot, altho slightly pricey for what at the end of the day is a plastic badge, but still not expensive. I like it, and its the closest I can get to a new one for a while! Thumbs Up Reformed
Post #105331 3rd Feb 2012 9:09pm
Ok maybe pull the back a little, what about just the seats?? I guess the rears wouldn't be too hard as they are just heated elements but the fronts with the memory functions tied in with the mirrors and so forth im thinking could be hard and it would have to be a none air cooled seats as well. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #105337 3rd Feb 2012 9:24pm
landyash
2007 Range Rover Vogue TDV8 Java Black
Would fit but might have a problem with the seats has the airbags are in the seats on the newer Range Rover, not in the doors.
Post #105353 3rd Feb 2012 10:13pm
Airbags in the seats can just be ignored, ie not plumbed in then so that saves one thing i guess Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #105356 3rd Feb 2012 10:19pm
landyash
Hi kingpleb,your right I was thinking more about door panels.
cheers Thumbs Up
Post #105359 3rd Feb 2012 10:28pm
I can see the dashboard and other bits would cause a lot of wiring work especially if they were cooled Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #105362 3rd Feb 2012 10:45pm
