![]() | Home > Maintenance & Mods (L322) > 2011 interior into a 2005 pre-facelift |
Can it be done, are the mountings and connectors the same and so forth??
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
Reformed is it like the 2011 badges??
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1510 ![]() ![]() |
It probably would fit physically , but a lot of things spring to mind why it would be far from plug and play. All the console buttons work over a different protocols, the vents are different , so would that mean a different heater, do the coolant pipes run through the bulk head differently etc etc etc V8 or else ... |
Given time and money you can do anything. You'd have to change nearly everything, tho. The switchgear is different in great part so you'd have to transfer the old electronics to the new bits and what would you do with things like terrain response or the parking brake ? (you could purchase a 12v linear acutator and build your own e-brake... |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3804 ![]() ![]() |
check you haven't stuck it on top of the air bag - its in a different place to the 07my, just in case it goes off in an impact and your wife / girlfriend has a RR badge sticking out of her ear. |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I have mine at the top just above the SRS clip, where as on the newer ones its slightly lower. I used Microcat to track down the part number and then ordered it from Dan at duckworths.
Ok maybe pull the back a little, what about just the seats?? I guess the rears wouldn't be too hard as they are just heated elements but the fronts with the memory functions tied in with the mirrors and so forth im thinking could be hard and it would have to be a none air cooled seats as well. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
landyash Member Since: 05 Jan 2012 Location: Nottinghamshire Posts: 72 ![]() ![]() |
Would fit but might have a problem with the seats has the airbags are in the seats on the newer Range Rover, not in the doors. |
Airbags in the seats can just be ignored, ie not plumbed in then so that saves one thing i guess |
Hi kingpleb,your right I was thinking more about door panels.
I can see the dashboard and other bits would cause a lot of wiring work especially if they were cooled |
