Home > In Car Electronics (L322) > reversing camera......works sometimes
Page 1 of 3 123>
JJN
2007 Range Rover Vogue Td6 Java Black
Hi
New to this
Just bought a lovely 2007 RR Vogue
Reversing camera occasionally works ?? Any quick fix suggestions appreciated
Post #104693 31st Jan 2012 10:15pm
spidermanUK
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Similar problem here!
The rear camera on my 06 4.2 has recently started playing up!
Sometimes it just displays a black screen, other times it displays a picture with a lot of interference, but you can more or less see the view to the rear of the car and very occasionally it displays a clear picture as it should.
Has anyone any idea what is causing the fault and more importantly, how to cure it?
Post #105900 7th Feb 2012 3:11pm
might be worth doing a search on the forum.. ... - .- -.
Post #105901 7th Feb 2012 3:12pm
You'll need a new camera £500 Shocked
Post #105902 7th Feb 2012 3:13pm
Vogue
+ fitting Shocked
Post #105907 7th Feb 2012 3:21pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
My camera stared playing up like this. Replacement camera was £140ish + fitting took less than an hour. Worked perfectly since.
Post #105933 7th Feb 2012 4:56pm
Vogue
David, where did you get your camera and what make / spec is it. LR have quoted me £600 ish plus VAT!
Post #106002 7th Feb 2012 9:23pm
For £140ish probably this ……
Laughing Laughing Laughing Wink Wink
Post #106018 7th Feb 2012 10:06pm
daveo
hi, not that bad..it will be the camera. the seal goes on them and the moisture gets in...but at the camera end you will have 12v and a signal so there are quite a few after market ones that can be fitted there if you dont want to pay landrover prices saying that i pick up a factory camera for 40 quid
http://www.ebay.co.uk/itm/LED-SENSOR-CAR-R...519ac296cd V8 facelift Range Rover Autobiography 22" wheels.
Post #106046 7th Feb 2012 11:32pm
Daveo... That link you posted, that camera will have similar wiring to the FFRR camera I take it? Previously..
Post #106053 8th Feb 2012 12:32am
daveo
yes its 12v and you will need to convert the rca to smc connector, you can pay more for better quality cameras but that or something along them lines, you will have to fix it under the spoiler V8 facelift Range Rover Autobiography 22" wheels.
Post #106056 8th Feb 2012 1:03am
DavidP
Camera came from Caffyns at Lewes.
edit to say it's an original part supplied by L/R
Post #106062 8th Feb 2012 8:23am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
My camera on 06 vogue is banjaxed, took off spoiler messed with the cables and nothing only flickers if I'm lucky. It is wrecking my head Crying or Very sad Any suggestions for a straight swap aftermarket camera that fits into the space for the old cam?
Post #107706 17th Feb 2012 12:04am
Lolo
Woohoo finally tracked down a genuine second hand one from cws4x4. 50 quid. Delighted.
Post #107877 18th Feb 2012 12:04am
Lolo
Help...
my camera arrived today, so i have just one question now, how do i connect to my car because the wires from my existing camera connection were cut and taped together(previous owner i assume).. The red and black wires will be easy to just tape together, but the gold connection, what do i do with that, should i cut it off the new camera or..?
Post #109099 24th Feb 2012 4:06pm
Page 1 of 3 123>
