Home > Maintenance & Mods (L322) > Help; rear brake binding
Page 2 of 3 <123>
Have experienced this on several SC's make sure you have both rear callipers replaced at the same time to be on the safe side... Other wise it could lead to an unexpected break down at an inconvenience time/place... They have a habit of chewing through pads and the heat will wreck your disc and could even cause brake failure due to heat in the fluid...
Craig Thumbs Up
Post #106499 10th Feb 2012 10:11am
vanquishspirit
I have been achieving 9mpg around home with the brake problem, but I reckon it was sticking on slightly before which is why it kept wearing the discs out, well to be accurate the offside disc which doesnt have a warning wire in the pads. Cheap! Anyway, before the 9mps it usually 14.5. Yuk, but I reckoned the depreciation of switching a 2006 to a 2012 TDV8 with an all new FFRR out next year would be way more than the fuel bill Smile
Post #106500 10th Feb 2012 10:11am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
As Craig said, I ended up getting both done albeit one after the other.
Rolling Eyes
Post #106535 10th Feb 2012 11:45am
swirl80
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I've had my 2007 FFRR for 3months now and started to hear a grinding noise, bit of investigation work i found it was the rear drivers side pad had completely worn to the metal and subsequently discovered it was cos of a sticking caliper. So having the disks (cos 1 is ruined), pads and calipers replaced by a neighbour as I don't want to drive it but my question is, should i complain to the $tealers about this?
Is it something they should have picked up in either:
a) their 100+ point check thats done before it goes out on the showroom floor
b) the MOT which was done in december by same $tealer
Not sure if i've got a leg to stand on.....?
Also, is there not a sensor that should have fired when the pad was getting low?
Post #111514 7th Mar 2012 5:40pm
the binding brake could have started the next day after you brought the range so i dont think you have a case with the dealer especially after 3 months.... ... - .- -.
Post #111516 7th Mar 2012 5:42pm
swirl80
thought that'd be the case Sad
For future reference, if there's no sensor on the outer pad (which is the one thats fooked on mine, inner is fine) and mpg is what i'd class as avg (32mpg on a run, 22-25mpg combined), how do i know i've got an issue. Didn't notice anything until i heard the noise and only heard that cos i had the window down which i don't often do.....
Post #111517 7th Mar 2012 5:53pm
As Stan states above, the brake caliper can stick on at any point unfortunately leading to ruined pads & discs... They can last a couple of hundred to a couple of thousand miles depending on how much the brake is stuck on! The more stuck the quicker it wears, i am surprised most drivers state the car drove the same.
Im sorry but it could have only been stuck on for a couple of hundred miles before you noticed!
I had a customer a couple of months back who's "wife" drove the car half way to London with the handbrake on! The rear shoes lasted 45 miles before failing... Ruining the whole of the rear brake system!
Craig Thumbs Up
Post #111624 8th Mar 2012 8:08am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Rolling with laughter
I must admit, with trip showing 13mpg I'm starting to wonder if brakes are
Stuck on !
Not had car long enough to know what "normal" is Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #171851 12th Feb 2013 9:43pm
Vogue
That's normal for a supercharged. It's good to get into double figures booting a Twisted Evil
Petrol RR
Post #171865 12th Feb 2013 10:19pm
Mrbadger
United Kingdom 2006 Range Rover Vogue 4.4 V8 Java Black
My ajv8 is at 16 and smells a bit, makes me wonder if I have the same issue too
Post #172338 14th Feb 2013 7:47pm
Any tips for freeing up the suck calliper to see if it temporarily cures it?
Post #246415 5th Mar 2014 12:07pm
you could try , wheel off, pads out, clean the pistons and ease them in slightly .. ... - .- -.
Post #246421 5th Mar 2014 12:27pm
The cost of JLR replacements are low now Gary. Not worth the strip down to free off then the same labour to do the job again for an extra £75ish for a JLR re-manufactured unit from Dan...
Post #246422 5th Mar 2014 12:28pm
mmm hands (very) dirty....
Ring Ring: Hi Roy can I bring the Vogue over..... Laughing
Post #246423 5th Mar 2014 12:29pm
Will buy a couple of units from Dan.
Is there an easy way of knowing if its Pads/Callipers or Handbrake drums?
Gary
Post #246425 5th Mar 2014 12:30pm
Page 2 of 3 <123>
