Home > In Car Electronics (L322) > T4 test book not working
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi all
I went to a local lr specialist this morning to do
An update on my car,
But the t4 test book would no communicate
With the car????
He tried a snap-on one and that worked fine.
Any one else had this issue 04 td6 RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #106777 11th Feb 2012 12:34pm
SteveMFr
Site Sponsor
The T4 would not communicate at all?
One issue we've had with more than one IIDTool user is the pins on the OBD connector not making proper contact.
If you look into the OBD connector on the vehicle, there is a little 'tongue' inside the square connectors that actually makes contact. It's a bit fiddly but try bending these for better contact.
It's solved all our customer's probs.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #106796 11th Feb 2012 3:19pm
Jr-auto-electrics
Ok cool I'll give it a try,
But why does the snap-on one work???
Also is the allcomms same as t4, or do the same upgrades RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #106804 11th Feb 2012 5:04pm
SteveMFr
Site Sponsor
Thicker pins. Could be the reason the T4 does not work.
AllComms has fault code read/clear and EAS calibration - and one or two functions in editing the ccf. Not nearly the same as the T4.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #106865 11th Feb 2012 10:54pm
Jr-auto-electrics
So basically I need to do a engine management software update
Is the t4 the only way to do it then??
Thanks for the help. RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #106866 11th Feb 2012 11:01pm
