![]() | Home > Technical (L322) > 4.2 06 SUPERCHARGED RR DIED |
| bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055
I believe there are two pumps, one in the tank, and another high pressure one further forward, the one in the tank seems to be prone to failure. I think if the car is run frequently at less than 1/4 tank full, it's prone to overheating, though it's probably due to fail with age now anyway.
| Goatboy1972 Member Since: 22 Sep 2011 Location: ESSEX Posts: 26
Good man I love a positive outlook.
Was it showing any symptoms before dying Bruce? i.e. any erratic behaviour or power loss? Mine did once, I put some juice in and it was fine again, and it happened to somebody else on the forum too. Always seems to be with just under quarter of a tank left. Was the same on my 530d when the pump failed on that.
| NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156
Sounds familiar.......
Looks like it should cost £300 plus an hours labour. I'm surprised that the pump costs so much, but then it's not just a pump!
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
from that thread;
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Am guessing it happens on the S/C as the pump can't keep up with the fuel demand from the engine |
You have two pumps in your tank, one is the main sender (supplies your engine and fuel gauge) the other one (smaller one) equalises the fuel on either side of the tank...
| RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 226
I have had this for 5 years, ever since I bought my 1 year August 2005 old supercharger.
Pump replacement is the only answer and it only comes as a full kit.
Gazellio,
No problem I paid for 1 hour fitting and it took 5.........
| JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889
I regularly run my 06 SC right down to almost empty and it never misses a beat, get it fixed and enjoy the whole fuel tank |
Hello all. Just to say that I had the entire pump system replaced .
| All times are GMT |
