Home > In Car Electronics (L322) > TV Tuner Confusion
Page 1 of 3 123>
SupaCharged
2005 Range Rover Autobiography Supercharged Java Black
TV Tuner Confusion
I have a 2005 (2006MY) SC with the touch screen monitor, RSE and analogue TV Crying or Very sad I recently bought a new TV tuner which I was told would work on 2005-2009 MY's , having just gone out to swap this over I have found the new tuner is smaller than the old one (LEAR) and has a green plug on it which is not on the old one.
question is will this fit and work on my RR ?
the sockets look the same but there isnt one for the green socket circled in Red below ? will this work on my RR without plugging in the Green plug ?
old (i.e. current analogue) with no green connector.
New , with green connector......
[/img]
Post #108774 23rd Feb 2012 12:15pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
That's the newer style digital tuner as fitted in a D4 but the green socket is not used on the D4 either so you will be fine - Just connect up the other coloured plugs correctly and you'll be sorted Thumbs Up
(Photo courtesy of wiggs Wink )
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #108777 23rd Feb 2012 12:41pm
SupaCharged
thanks Ajay, will install it tonight then , many thanks
Post #108810 23rd Feb 2012 3:24pm
Johnte
What is the extra socket for ? Confused
Post #108853 23rd Feb 2012 6:05pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Not sure.
It is also fitted in Jags, so maybe they use it.
I left my analogue tuner in place and just stuck the new one to it and changed over the plugs.
Took about 5 minutes.
Post #108867 23rd Feb 2012 8:01pm
Johnte
I took my old one out, and bolted the new one in.. If you're going to do it this way, you will need to drill two more holes for the bottom mountings. I also put some spacers (2 washers on each mounting point) to allow for better air flow, as well as drilling holes in the mount opposite the fan.
Post #108878 23rd Feb 2012 8:52pm
SupaCharged
I've fitted it tonight but can't get it to work,I can't select TV/DVD from the audio menu , press it and nothing happens, tried power cycling the whole car with a battery disconnect as well, still nothing ..... I'm thinking I might have a dud tuner.
Am I missing anything , I there anything should be doing except plugging he new unit in?
Post #108898 23rd Feb 2012 10:38pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
What do you mean nothing happens? Does it display anything on the screen at all?
If it does, try hitting the 'auto' button and see if any channels load, also try the 'settings' button and make sure its set to the UK.
And if it still does nothing, send it back, drive to cambridge and buy mine and I will fit it for you Thumbs Up
http://www.fullfatrr.com/forum/topic9893.html
Gone - Range Rover Supercharged 2006
Post #108904 23rd Feb 2012 11:05pm
SupaCharged
Pressing tv/DVD It literally does nothing , it doesn't go to the tv/DVD screen so I can't select any options , using the 753 diag menu it says "comm error" or something similar...... Plug the old analogue in and it all works again , albeit analogue.... Sad
I'll get in touch with the seller for a refund , if that works out I might take you up on that offer ... I have RSE though ...... Cool So full fitting is a bit of a pig...
Post #108910 23rd Feb 2012 11:41pm
When i fitted mine i had a problem with the green and brown ariel plugs connecting with the new unit (no signal and then no comms)... Make sure you have good connections on all plugs before you take it all back out maybe wasting your time Embarassed
Craig Thumbs Up
Post #108916 24th Feb 2012 12:05am
SupaCharged
Have double checked and reseated all connections three times ...... Still no good Sad
Post #108917 24th Feb 2012 12:12am
No worries, worth a mention...
Craig Thumbs Up
Post #108919 24th Feb 2012 12:21am
SupaCharged
JustinP, you have a PM......
Post #108946 24th Feb 2012 8:38am
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
So I installed my digital tuner, I chose pal 1, when I select auto there are 4 channels loaded but it will only show one channel won't let me change the channels..any ideas?
Post #109095 24th Feb 2012 3:42pm
wiggs
Have you all who are having problems purchased the cheap ones from eBay ?
Post #109290 25th Feb 2012 11:15am
Page 1 of 3 123>
