Home > Maintenance & Mods (L322) > 52 RR Vogue TD6 hesitating when accelerating
jimwise68
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
My 52 RR has just started to hesitate/judder when accelerating.
Drives ok normally and revs ok out of gear when stationary, only happens under load.
Kickdown works fine, starts to accelerate then engine starts to misfire/judder/hesitate. All very rhythmic too.
Any ideas?
Post #110063 29th Feb 2012 1:22pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
I'm no expert, but my first thought is fuel pump, or injectors. Does it happen only under hard acceleration?
It may be the high pressure pump. Does it make any difference how much fuel you have? 2012 SDV8 Vogue SE
Post #110072 29th Feb 2012 2:12pm
jimwise68
Yes it's only under hard acceleration. Fuel level is irrelevant.
But. As mentioned out of gear and revved up to 4k no hesitation.
Post #110075 29th Feb 2012 2:15pm
When did you last change your fuel filter?
Post #110079 29th Feb 2012 2:28pm
jimwise68
Errr bought the car last August, it came with FLRSH so presume its been changed when it should.
Will check the paperwork later.
Post #110085 29th Feb 2012 2:41pm
Presume nothing, especially where main dealers are concerned. Whistle Smile
Post #110088 29th Feb 2012 2:51pm
jimwise68
Where us best place to get fuel filter? Is it a standard inline or a specific RR item?
Post #110096 29th Feb 2012 3:20pm
Duckworth Dan is the man Thumbs Up
Post #110104 29th Feb 2012 4:04pm
Had similar issues..
http://www.fullfatrr.com/forum/topic1179.html?highlight=fuel+pump Discovery 4 HSE
Post #110176 29th Feb 2012 11:03pm
jimwise68
Thanx RRUK. Just read your post. It's exactly same as nine. 3,000 rpm and the stuttering starts.
Saying that I drove it back from station and it was fine. Popped out again and it done it. Sounds like its not fully gone yet but will get the pump and filter. Where are they situated on car?
Post #110201 1st Mar 2012 12:21am
The fuel pump in question is external to the fuel tank on the chassis, therefore easier to swap out. There's an in line fuel filter I think but also a fuel sediment filter trap under the bonnet which is a £10 part you can swap yourself as I did when I gave the TD6 a service.
See here:
http://www.fullfatrr.com/forum/topic746.html Discovery 4 HSE
Post #110228 1st Mar 2012 10:22am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Had the exact same issue in the last month, low pressure fuel pump as previously mentioned.
Post #110257 1st Mar 2012 1:11pm
jimwise68
Thanks for the info. Im ordering one once i get the part number from the local Stealer.
Post #110260 1st Mar 2012 1:13pm
Mr Tee
Get in touch with Dan 01673 844 722
Post #110292 1st Mar 2012 4:09pm
jimwise68
Situation update: changed the fuel filter abd problem solved.
Car feels much more responsive too.
Looked like the fuel filter had been on for some time aswell.
Thanks for all the input guys.
Post #110690 3rd Mar 2012 5:07pm
