![]() | Home > Maintenance & Mods (L322) > 52 RR Vogue TD6 hesitating when accelerating |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I'm no expert, but my first thought is fuel pump, or injectors. Does it happen only under hard acceleration?
jimwise68 Member Since: 29 Feb 2012 Location: Chelmsford Posts: 12 ![]() ![]() ![]() |
Yes it's only under hard acceleration. Fuel level is irrelevant.
When did you last change your fuel filter? |
Errr bought the car last August, it came with FLRSH so presume its been changed when it should.
Presume nothing, especially where main dealers are concerned. |
Where us best place to get fuel filter? Is it a standard inline or a specific RR item? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Had similar issues..
Thanx RRUK. Just read your post. It's exactly same as nine. 3,000 rpm and the stuttering starts.
The fuel pump in question is external to the fuel tank on the chassis, therefore easier to swap out. There's an in line fuel filter I think but also a fuel sediment filter trap under the bonnet which is a £10 part you can swap yourself as I did when I gave the TD6 a service.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2700 ![]() ![]() ![]() |
Had the exact same issue in the last month, low pressure fuel pump as previously mentioned. |
Thanks for the info. Im ordering one once i get the part number from the local Stealer. |
Get in touch with Dan 01673 844 722 |
Situation update: changed the fuel filter abd problem solved.
