Home > Maintenance & Mods (L322) > Front Wheel Arch Liners
supershuttle
Well today I got round to fitting my side vents but I thought while I was at it I would tidy up the previous installation of the mudflaps/side steps. All went pretty well but the fixings, screws bolts etc are not really reusable and so I have ordered some more, currently mudflaps and lower panel are not refitted.
But the thing I am struggling with is the wheel arch liners, they are currently distorted probably due to not being trimmed when the steps and mudflaps were originally fitted. I say that because I've read somewhere, probably here, that you need to trim the wheel arch liners after fitting mud flaps. Is that the case? currently mine are pushed back a little at the bottom near the mudflap and also don't sit behind the lip of the wheel arch at the top.
So help is the cry Very Happy can anyone cast some light on what I need to do to fix this Bow down
Thanks Geoff
Post #110710 3rd Mar 2012 8:22pm
Googsy
I have this issue on one side of mine still to fix. On the other side however I pre drilled hole through liner if that makes sense and was able to insert the screw into the arch liner which then stayed flush.
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #110711 3rd Mar 2012 8:24pm
simon1233
Hi Geoff
My wheel arch liners were dreadful when I got my car, massive gaps at the bottom and they wouldn't stay inside the metalwork at the top of the arch. The dealership just replaced them with new ones and they seem better. Still looks a little messy at the bottom where the gaps are a little larger than I would ideally like but much improved overall. My car has never had mud flaps
Post #110716 3rd Mar 2012 8:55pm
supershuttle
Those Simon are my symptoms in a nutshell. What I read suggested poor mudflap fitting but actually with my head under the wheel arch this afternoon, I did think poor liner fitting full stop. What I will probably do is loosen all the fixing points for the liner and see if it can be persuaded Very Happy to sit a little better. I still think there is a bit of trimming to be done of the liner but I shall just snip away where it seems appropriate.
Obviously wont be doing much else until fleabay delivers the various nuts, bolts and glue that I've ordered Laughing
Thanks Geoff
Post #110718 3rd Mar 2012 9:06pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
I was a little offroad in mine this week with work and just washed it down as was filthy and find that on both sides at the rear of the front wheel arch the liners and fixings have gone awry presumably due to all the mud and stuff being flung at them but also both sides the rear plastic panel below the grills is flapping about at the bottom edge and it looks like fixings at the front are broken.
Has anyone got a blow up diagram or something of how the liner, the inner wing and the plastic panel are supposed to fit together?
I am tempted to buy some mudflaps and use the screws or scrivets through these to old all in place. Anyone any advice???
T
Post #119842 1st May 2012 8:46pm
tomthevet
Ahah found the answer with one of the powerful UK videos. Might be investing in some side steps and integral mudflaps. Better stop after this glass!
T
Post #119845 1st May 2012 9:00pm
Try heating the liner with a hair dryer or hot air gun and reshape them
Post #119862 1st May 2012 9:45pm
supershuttle
Forgot to say, I heated them with heat gun and "moulded" them back in place finished off with some black PVU adhesive to hold them.
All fine now. Geoff
Post #119882 1st May 2012 11:15pm
I heated a blade of a Stanley knife to carefully trim the liners around the mudflap mounting brackets and then "persuaded" the liners to spring back into position.
Got a good fit with no holes.
Definitely made trimming the liners easier.
Post #119902 2nd May 2012 8:53am
tomthevet
I have gone off the side steps partly as someone else obviously wanted them on ebay!! Maybe its someone on here?!
Anyway I am going to go just the mudguards route.
My car is a 2005 touchscreen model with but with chassis no starting in a 6. What is the difference in the mudguards needed for a pre 2006 car with a post 2006 car as I dont want to pick the wrong ones but then again I didnt think the bodywork itself changed between 05 and 06.
Problem is some flaps say for cars up to 2006 and other say for cars up to chassis no. 5a999etc.
Am confused!!!
T
Post #119997 2nd May 2012 8:07pm
Two types of flap available... One triangular and really quite large but stiff... The second alot more subtle and thinner and more flexible off road, the later is thinner type...
Hope that helps...
Craig Thumbs Up
Post #120015 2nd May 2012 11:47pm
If anyone is passing the Stroud valley M5 JN13 i have loads of used front wheel arch liners to give away free!!!
Craig Thumbs Up
Post #120016 2nd May 2012 11:48pm
daveo
hi craig, are they 06 onwards as i have the pre face lift ones that have the gap at the bottom due to having the face lift done...
thanks dave V8 facelift Range Rover Autobiography 22" wheels.
Post #120019 2nd May 2012 11:53pm
Have both types fella...
Craig Thumbs Up
Post #120021 2nd May 2012 11:57pm
daveo
hi craig, do you know what i am talking about the gaps at the bottom of the liner in the front wheel arch, please can i ask for you to put a set aside and i will get them collected.
thanks daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #120026 3rd May 2012 12:19am
