![]() | Home > Technical (L322) > Vogue Se supercharged remap. |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
Paul..Would have thought that a S/C had plenty power as it is TBH...not sure if the car could handle too much more as it's designed to be more of refined cruiser rather than an out and out roadster, which is the reason for buying them |
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 217 ![]() |
That might be your reason for buying one |
SupaCharged Member Since: 30 Dec 2011 Location: England, Herts Posts: 29 ![]() ![]() |
Id like to know if there is a remap option out there on this basis also.... |
npikey Member Since: 14 Nov 2011 Location: Lincolnshire Posts: 59 ![]() ![]() ![]() |
Only thing ive heard of is fitting a smaller pully on the supercharger, Fairly easy mod by the sound of it |
In my experience the S/C is already very very smooth whatever you do. I do suggest to ensure that you have all the newest/latest software updates installed. This will make it more fuel efficient (although that term should be used very loosely with a S/C) anyway and increase soomthness |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
Bit of a separate question here but is there any way to double check that the latest software / firmware has infact been applied?
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Check out JE Engineering as a starting point. What they don't know about the LR range of engines isnt worth knowing. Discovery 4 HSE
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 ![]() ![]() ![]() |
Smaller pulley on the supercharger fitted, and a remap to the DENSO ecu and you get some nice gains out of the 4.2 engine.
How much more strain dies that put on the supercharger/engine though? I guess it just raises the boost?
