Home > In Car Electronics (L322) > Lost sound whilst adding the new kit.....
CUE99T
I seem to have lost the sound in my car whilst doing my upgrade. The screen when showing TV when on AV showing pictures from either my DVD player or Digi TV Tuner which are both Alpine weren't playing sound so I've now put it back to stock and it's not playing even the radio.....not a happy bunny!!
I have tried to unplug the 3 plugs on the Lear AMP after a few searches on here and other forums but I can't get the 3rd main block out....how do I get this out? the others seem easy over the top clasps.
We were using the power from this temporarlily today by inserting the power cable freely, so unsure if maybe I've blown the fuse for the Amp but socket 8 for the 5amp fuse seems ok, and thats the only audio one listed in the book. Does anyone know the exact one for the amp, and does the Lear Amp have one itself to put sound out to the speakers?
Basically I think I've blown the AMP....how can I tell if it's on and working? Is there a power out from it I can check? Or a light on it anywhere?
As a side note:-
I seem to have a permamnent red light on the DVd which is causing drain, anyone any ideas......I think it might be bust??? It works but I've got an inline switch to cut power currently. all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #110903 5th Mar 2012 12:41am
Fuse 8 is listed as Radio, and does deal with the sound too. Try changing the fuse, you never know? All the juice for the stuff in the boot seems to be on that fuse?
Are you sure the DVD light is on permanently? Mine goes off after @ 3 minutes if I have the boot open and the side panel off. .
Post #110949 5th Mar 2012 10:22am
You get the power plug off the lear amp by sliding the base of the plug to the right and then pulling the plug off.
Have you got DSP indication on your screen?.
Post #110955 5th Mar 2012 10:56am
CUE99T
Cheers Joe. And yes it doesn't go off.....maybe it's broke....seems to work ok. I think thats why there is an inline switch.
Whats DSP indication.....i.e. the BAS Treble etc?
I can see all the usual on the screen..... all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #110957 5th Mar 2012 11:00am
DSP should indicate on the main menu screen.
Have you tried disconnecting the battery, leaving for 10min and reconnecting.
You might get sound back.
Post #110964 5th Mar 2012 11:19am
CUE99T
Done the battery for for 3 hours ysterday...nothing.....I think the fuse for it might have blown I'll try the radio fuse also thats in the radio module in the boot. apparently theres one there. all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #110973 5th Mar 2012 12:31pm
Fuse under the power plug on the radio, 10A
Post #110977 5th Mar 2012 1:21pm
Ah yes, forgot about that one Smile[/b] .
Post #110979 5th Mar 2012 1:28pm
CUE99T
So I presume that's the full body section out next to it job for that fuse??? all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #111083 5th Mar 2012 10:04pm
CUE99T
Yes DSP is in black so clearly the AMP is not running.......
How do I get the Radio module out....do I need to take out half the flipping boot????
P all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #111183 6th Mar 2012 1:11pm
To get to the radio tuner involves very little work.
Remove the main central floor panel.
Remove the side vertical access panel.
Undo the bolts on the left hand floor panel including the tie down loop.
"Pull" out the rearmost vertical carpeted panel.
Pull out the side floor panel.
Unplug the connections to the tuner
The radio tuner is held in with one bolt at the top.
Lift the tuner out.
Simples Smile
Post #111195 6th Mar 2012 2:14pm
CUE99T
cheers mate, in a call all day with work so maybe have a go tomorrow......playing snooker for the team tonight. all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #111207 6th Mar 2012 3:38pm
On mine there is a fuse inside the big black socket on the top of the radio, no need to remove?
Post #111219 6th Mar 2012 4:49pm
CUE99T
bust power pin on AMP.....clearly broken off with corrosion....not sure what to do as it's working sometimes!!!
total pain as got the rest of the RSE in now with no flucking sound!!!!! all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #113029 14th Mar 2012 2:30pm
I had a broken/corroded pin on my dsp amp.
There are people around who will fit a new socket, I got round it by opening up the amp and soldering a thin cable to the appropriate terminal in the amp, bringing the cable out of the amp and then splicing into the appropriate cable connected to the plug.
Effectively bye-passing the broken pin.
Not too difficult a job. Everything now works ok. (For now Very Happy )
Alternative is about £700 for a new amp.
Post #113032 14th Mar 2012 2:46pm
