Home > Maintenance & Mods (L322) > Got new style flip key to work..!
Page 1 of 9 123456789>
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
There are so many topics bout keys I thought I'd just start a nice fresh one. I got my new flip style key working. Delighted looks great. It was simples. Very Happy
Post #111495 7th Mar 2012 4:57pm
ebajema
Congrats, now spill them beans mate. How the freak did you do it ????????????????????????
I can't get my flip keys to open and close the doors, the transponder issue has been resolved !! MY 2010 5.0 SC Galway green and sand interior!!
Post #111499 7th Mar 2012 5:01pm
Lolo
Hhhmm I might keep it a secret, or u could pay me to tell u.. Razz
Post #111500 7th Mar 2012 5:03pm
Lolo
So i got this info off rangerovers.net. But I'll share my experience.
Order key from http://www.autokeytransponder.com/Product_details.php?id=2329
When u get it bring blank key to a good security shop, like those places that sell safes, cctv etc.My locksmiths could not do it, local car key place refused and honestly laughed at me when I said what I was tryingto do.
Check new cut key works in door.
Put transponder wedge thing from old key into new key. Put new cut blade in. Put cable tie back on, don't glue anything till ur sure it all works.The flip key is fiddly cause u have to put it on the spring and wind it (you'll know what I mean)
Put in ignition, ( I thought it wasn't going to work cause the immobilser normally goes off as soon as the old key is ner the ignition. This took a few seconds till I turned the new key.
Go for drive to charge it.
Open close doors and proceed with the key programming sequence. Took a few goes, after each failed attempt I opened and closed the door to start fresh. After many tries, I heard that lovely sound of the doors locking. Bingo. All sorted.
[/list]
Post #111511 7th Mar 2012 5:31pm
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
DAMN !!!!!!!!!!!!!!!!!!!!!
just went on to buy one,
they have none in stock
sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #111532 7th Mar 2012 6:47pm
ebajema
I have two of which both don't work on the doors yet but then I did not try many times. So next thing is, try try and try Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #111534 7th Mar 2012 7:02pm
you can get them for about £12 on ebay... ... - .- -.
Post #111537 7th Mar 2012 7:13pm
Lolo
I don't think that's with the internals tho? I had to tell them the mega hertz that i needed and that so I could use the remote part.
Post #111545 7th Mar 2012 7:40pm
you're correct , only the blade and case... ... - .- -.
Post #111547 7th Mar 2012 7:45pm
ebajema
I paid about 50 USD for the complete second hand key (for the internals) and 12 GBP for the new empty housing. Switched the blade from the donor key to the flip key, same as the transponder. Used the flip key for a while to charge the battery, checked the battery voltage so now it is trying trying trying to get the door lock part working !
I have a NAS car so I ordered the remotes from the US (ebay) and they have the correct markings for a US/Canadian car by the way Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #111549 7th Mar 2012 7:46pm
Lolo
Im not sure bout these things but different countries have different frequency remotes, so the remote u have might not work with ur transponder module in ur car..??
Post #111561 7th Mar 2012 8:18pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I ordered a used BMW key for the inner transponder, has to be 433Mhz. I got a black flip key from the bay with the new blade (same style as the Range Rover blade (there are two versions).
You can remove the old transponder from the BMW key (8 legged chip next to the copper wrapped charger thing). To keep it charging you need to put a wire to bridge between to contacts where the chip was.
http://ianparsons.info/photogallery/3933.jpg
Pop the transponder from your old key in to the new one, make sure the buttons line up. test it well before sealing.
You should then be able to program the new key for door locking by doing the following procedure:
1. With all keys, get in the car and close all windows and doors.
2. Put working key into the ignition and turn to position 1 (the accessories should turn on)
3. Turn the key back to position 0 and take the key out of the ignition.
4. Using the working key, hold down the unlock button, press the middle button (lock button) 3 times, and release the unlock button. Doors should lock and unlock.
Repeat this with all working keys within 15 seconds of each other and they should all do the lock and unlock thing now.
This system keeps the charging option working so you will not have to replace the batteries. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #111568 7th Mar 2012 8:28pm
Lolo
If u buy from the place I got mine all u have to do is transfer over the little black chip from ur old key , get key cut, reprogram..Pity they don't have any in stock..It fits in perfect too, some people worried the key cant get in far enough cause of remote shape but it's grand..
Post #111584 7th Mar 2012 9:04pm
Flashman
Lolo, so the electrics you got were for the flip key? You did not have to move a diamond key inner workings across? That makes things nice and simple, and you get to use all 3 buttons! How much was the unit, the site is out of stock so does not say. Tom
Current Drive
Previous Drives
Post #111586 7th Mar 2012 9:10pm
Lolo
Yes they sent the unit with the circuit board or whatever u call it in it.. Thumbs Up I didn't have to get diamond key. Just their key, altho there are 3 buttons on the flip, haven't tried the 3rd key to see what it does.. My car is 05 reg 06 model.. I am going to go back to the guys who laughed at me and gloat..
Post #111591 7th Mar 2012 9:21pm
