![]() | Home > Maintenance & Mods (L322) > Got new style flip key to work..! |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Congrats, now spill them beans mate. How the freak did you do it ????????????????????????
| Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608
Hhhmm I might keep it a secret, or u could pay me to tell u.. |
So i got this info off rangerovers.net. But I'll share my experience.
| salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332
DAMN !!!!!!!!!!!!!!!!!!!!!
I have two of which both don't work on the doors yet but then I did not try many times. So next thing is, try try and try |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35875
you can get them for about £12 on ebay... ... - .- -.
you're correct , only the blade and case... ... - .- -.
I paid about 50 USD for the complete second hand key (for the internals) and 12 GBP for the new empty housing. Switched the blade from the donor key to the flip key, same as the transponder. Used the flip key for a while to charge the battery, checked the battery voltage so now it is trying trying trying to get the door lock part working !
Im not sure bout these things but different countries have different frequency remotes, so the remote u have might not work with ur transponder module in ur car..?? |
| Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1244
I ordered a used BMW key for the inner transponder, has to be 433Mhz. I got a black flip key from the bay with the new blade (same style as the Range Rover blade (there are two versions).
If u buy from the place I got mine all u have to do is transfer over the little black chip from ur old key , get key cut, reprogram..Pity they don't have any in stock..It fits in perfect too, some people worried the key cant get in far enough cause of remote shape but it's grand.. |
Lolo, so the electrics you got were for the flip key? You did not have to move a diamond key inner workings across? That makes things nice and simple, and you get to use all 3 buttons! How much was the unit, the site is out of stock so does not say. Tom
Yes they sent the unit with the circuit board or whatever u call it in it.. |
