Home > Technical (L322) > Low Oil Pressure
wookey
Low Oil Pressure
Hi Guys,
Newbie here, sorry my first post is a question.
I've got an 02 TD6 Vogue with STOP! LOW OIL PRESSURE warning coming up on the dash a few seconds after starting the engine.
So far I've checked the oil level which is fine, changed the oil pressure switch and checked to make sure the new one works (which it does).
I've just put an oil pressure gauge on the engine and tested at tick over and 2000rpm and that seems fine. Pressure at tickover was approx. 30psi and 60psi at 2000rpm.
Does anyone know the exact spec for oil pressure/rpm? I've downloaded a workshop manual but that doesn't have it.
Thanks.
Post #111521 7th Mar 2012 5:58pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Those pressures sound absolutely fine!
GENERAL DATA
Type 3.0 litre in-line direct injection diesel, 4 valves per cylinder, turbocharged
and intercooled
Cylinder arrangement 6 in-line, No. 1 cylinder at front of engine
Bore 84.00 mm (3.307 in)
Stroke 88.00 mm (3.465 in)
Capacity 2924 cm 3 (178.4 in 3 )
Firing order 1 - 5 - 3 - 6 - 2 - 4
Compression ratio 19.0 : 1
Direction of rotation Clockwise viewed from the front of the engine
Maximum power 130 Kw (172 bhp) @ 4000 rev/min
Type Common rail, direct injection fed by Bosch high pressure delivery pump
Maximum governed speed 4750 rev/min
Idle speed 790 ± 50 rev/min
Glow plugs 6 – 1 per cylinder, positioned centrally in portion inlet side.
Turbocharger Garrett GT 2256V
Lubrication
Type Wet sump, pressure fed
Oil pump type Crankshaft driven, eccentric rotor
Pump outer rotor to body clearance
0.080 to 0.156 mm (0.0031 to 0.062 in)
Filter type Disposable canister with full flow by-pass
Relief valve opening pressure 4.2 bar (60.9 lbf.in 2 )
Low oil pressure switch opening pressure 0.2 to 0.6 bar (3.0 to 8.8 lbf.in 2 )
Regulated pressure 4.2 ± 0.5 bar (60.9 ± 7.3 lbf.in 2 )
Post #111527 7th Mar 2012 6:24pm
wookey
That's brilliant thanks Simes.
The 'Low oil pressure switch opening pressure 0.2 to 0.6 bar' is interesting as that's about 9psi and the oil pressure gets nowhere as low as that!
So I can't understand why the switch opens Confused
Post #111589 7th Mar 2012 9:20pm
fisha
Ok - if the switch is ok / new and the pressure is OK ( measured independently ) then maybe worth looking at whether the switches signal is reaching where its meant to go?
Or... it it the only pressure switch on the engine? could there be a second one which the ECU is also reading? V8 or else ...
Post #111593 7th Mar 2012 9:33pm
wookey
A friend put his Snap-on computer on and looked at the pressure switch and you see it change on/off.
I spoke to the LR parts department when I ordered a new switch and only one came up on their system.
What I can't get my head around is why the switch changes state when the pressure doesn't drop.
Post #111596 7th Mar 2012 9:41pm
wookey
Even though it was only serviced less than a 1000 miles ok, do you think it's worth doing an oil and filter change?
Just to rule out the garage using the wrong spec oil?
Post #112225 10th Mar 2012 11:33am
just wonder if the garage did fit the correct filter and like you say, the correct oil....the oil specs for the range are on the wiki and with that info in hand , talk to the garage.. ... - .- -.
Post #112231 10th Mar 2012 12:01pm
Have you considered the low oil pressure may be connected to the themostatic valve serving the oil cooler?
Post #112235 10th Mar 2012 12:08pm
wookey
No I hadn't....tell me more lol
Post #112505 11th Mar 2012 8:51pm
