![]() | Home > General > Laboured start !!!! |
The battery club will be along shortly....
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
Hi yes it started ok, but as I have only had it 3 weeks and because of this obsession with the car
Battery or starter motor. I believe the starter motor is a swine of a job on this vehicle |
You need a good 10-15min drive to put a decent amount of juice back into a battery after starting it otherwise your just draining it even more |
Thanks guys,
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746 ![]() ![]() |
I would go for this one -
Hey thanks now then the promo code,
BATTERY15 |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Definately go for the 110. When you fit it, it might seem that it will never fit but it does, albeit very tight! Reformed |
The SC does sometimes need a little prod of the accelerator pedal...... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8117 ![]() ![]() ![]() |
To fit the battery you need to open the bonnet fully (access mode) by disconnecting the struts.
Thanks guys,
Use the code ukpas25 for a 25% discount which will bring the battery price down to £99.86 and a saving of £33.28 |
With batteries on these cars, in a "cold" climate like the UK, I suggest to go for the biggest capacity that you can find (Ah and CCA) to fit. It is a bit like the old American saying "there is no substitute for cubic inches" with batteries that should be amps |
