Home > Technical (L322) > TD6 battery drain located!! (fuse numbers enclosed) - HELP!
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Hi all
As most of you will know I've had a drain on my new Varta I1 battery that has sometimes been running it flat within a week to 10 days Sad
Bought a fuse drain tester as advised by a few of you and found 3 fuses with a draw, they are:
Fuse 28 - headlight cleaning @ 0.12a
Fuse 27 - glovebox light @ 0.47a (when open)
@ 0.13a when closed
Fuse 12. Starts off at 1.28a
Drops to 0.82a after 10secs
Then sits at 0.26a
Are any of these 3 common issues? And how do I go about resolving them?
I've only checked the top row of fuses so far as can't get to the lower row with the tester, is it easy to release the glovebox cover so it hangs down freely?
Thanks in advance everyone
Post #113522 17th Mar 2012 1:35pm
A1GSS
Releasing the glovebox - push the hinge stop strip to the side whilst taking the weight of the glovebox lid - then swing the box lid down. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #113551 17th Mar 2012 3:23pm
mrblonde
Cheers A1GSS
Does anyone know if the 3 fuse nubmers are a common fault? Or are the values high enough to be a drain?
Thanks again
Post #141282 15th Sep 2012 5:19pm
A1GSS
Very Happy
Could be a record for the longest ............................ pause ............................. between posts...? Graham
____
Post #141283 15th Sep 2012 5:22pm
Fuse 28 headlight washers/wipers
Could be a faulty headlight washer/wiper relay allowing current to pass.
Fuse 27 glove box light, interior lights, windscreen washers and analogue clock. All common to BCU.
No idea. Smile
Fuse 12 ac and heated front seats. Supplies ac blower motor.
Almost certainly faulty FSR.
Collectively you have at the moment 510mA current drain, acceptable would be about 30-40mA.
No wonder your battery drains. Very Happy
Post #141289 15th Sep 2012 5:57pm
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
hi
i had the same current drain as you ,traced it to faulty mk3 sat nav drive, fitted another sat nav disc drive problem solved, 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #141295 15th Sep 2012 6:54pm
mrblonde
Cheers guys (and Graham, sorry........... For........ The...... Long pause)
Nicedayforit, I changed the FSR last year so doubt it could be that? Open to suggestions though.....
STEVE57, what fuse was you getting the drain on? And did you change the whole drive? What was the cost of this, and where did you source one from?
Thanks again everyone
Post #141345 16th Sep 2012 10:11am
STEVE57
Hi
I had the exact same readings as you same fuses , i put in a bmw mk 4 sat nav drive , got it from ebay. This is the later dvd sat nav. Bought the updated software and dvd map disc, search google for bimmer nav, the change from mk3 to mk4 nav drive has been covered on here, as i said earlier , my original mk3 nav drive was not shutting down, even though the red light was off. I was told there maybee a problem with the nav drive
. I hope this helps 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #141348 16th Sep 2012 10:34am
mrblonde
Cheers Steve, will take a look.. It's one of the mods I been considering anyway
Is there a way of testing it first? Like removing the mk3 unit and seeing if the drain disappears?
Thanks again
Post #141353 16th Sep 2012 11:33am
STEVE57
hi
yes you can unplug the nav drive, my mk3 nav drive was warm on the bottom of the outer case 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #141364 16th Sep 2012 1:13pm
mrblonde
Cheers Steve
Anyone, is there a way of testing to see if it is the satnav first? Can i unplug the unit, if so where and what plugs? Or can i pull a fuse somewhere?
cheers
Post #143170 26th Sep 2012 4:37pm
mrblonde
Thanks for your calculation of my total drain, can you please show how you come to that value? (genuinely interested). I'm assuming fuse 12 is my biggest drain, how would i look into this further?
Thanks again
@ 0.13a when closed
Then sits at 0.26a
Post #143171 26th Sep 2012 4:40pm
Headlight cleaning 0.12A ie 120mA
Fuse 27 0.13A ie 130mA
Fuse 12 0.26A ie 260mA
Add all the mA and you get 510mA.
Post #143192 26th Sep 2012 6:09pm
mrblonde
Thanks again nice
Fuse 12 (ac, heated seats, blower etc), I put a new FSR in a few months ago so doubt it could be that? Also, if I was to just remove fuse 12 and not use ac, heated seats etc would that temporarily eliminate the drain? (sorry not sure how it works)
Cheers
Post #143363 27th Sep 2012 5:23pm
Removing fuse 12 will stop the battery drain going thro that fuse.
It may well switch off all ac functions ie heating, cooling and ventilation.
It may also switch off all the seat functions ie movement and heating.
I'm not certain how many functions you will loose, could be them all.
The battery drain on that fuse will stop though. Smile
Imo I wouldn't rule out the new FSR causing the battery drain, new or not it is still the most likely candidate. Unfortunately I know of no way to test them other than by replacement.
I suppose you could put the car on a diagnostic unit, it may show the fault.
Sorry I can't be more helpful.
On reflection, there is one thing you could do.
Disconnect the battery earth and leave the car for an hour.
Then touch one of the terminals on your ammeter to the the battery -ve terminal and the other terminal of your ammeter to the earth point nearby.
You may need to fit a length of cable to one of the terminals to do this.
Doing this means that your battery is connected to earth and as such the total battery drain on the car will be evident.
Be interesting to know if it's different to the total fuse drain.
Post #143367 27th Sep 2012 6:05pm
