![]() | Home > In Car Electronics (L322) > Post 2005 iPod connection |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Bump.. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
This is a funny one, I listen to Radio 2 pretty much all the time I am in the car, music from my era and no adverts. However, I do have an iPhone 4S which syncs with the car fine and so I kept it hidden away under the armrest all controls, phone book etc coming through via BT module (Wiggs upgrade) onto centre display and steering wheel, voice control also works (in sometimes amusing ways).
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
The reason for me fitting the LROE kit is because i like the quality of the sound in my VSE (which you loose with an aux lead) and also use my iPod/iPhone on shuffle. So its like my own radio station, be it at home/workshop or car. With the kit installed it means i can hit FF to move onto the next "shuffled track" without looking at the phone or taking my hands off the wheel...
Can u post a link for that product ..? Google not showing anythIng. Is it difficult to install? The thoughts of running leads front to back is a killer for me.. |
Me or Supershuttle? Lolo
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
+1 genuine LR Audio kit for me in my 06.
U Craig.. |
As above Lolo, speak to your local main agent first... Mine is the kit for the 07> model and as Happymaddison states above took me around 2-3hrs to fit...
Not that I wish to start an argument in this almost empty room. How can the sound be better than using the Aux port? all are analogue inputs, inc the CD player which will produce a better sound because of the audio codecs used to record a shop bought CD, that's why you can only fit about 20 or so tracks on. There may be some slight impedance issues but that won't affect quality only volume. The possible shorter and separate higher quality cable connections may have a very slight effect but sadly digital it ain't and that would be the only way to get a significant improvement.
I agree, I am looking for ANY solution |
The ACM is digital as is the CD Player, the MOST interface means that the DAC isn't done on the changer like it is in a conventional split mount audio system.
Happy- are u saying there is an aux port on the back of the touchscreen? ..!????mines a 06 model.If so that will do me just fine. |
Hey Lolo,
I have an AUX in said place .... and no RSE. Land Rover Addict
