Home > Maintenance & Mods (L322) > Wiper Arm Sheared Off
Coming home tonight in the rain noticed that my drivers side wiper was getting further and further away from the A pillar , luckily i got home before it wouldn't wipe at all .
So when the rain stopped went outside took off the cover and the retaining nut to find that the grooved slot in the base of the wiper arm had sheared off …..
Anyone know what the tool is called to try and pull up the spindle so that i can re align the new wiper arm when i get it …. or know how to get it off any other way ….
TIA Thumbs Up
Post #113857 19th Mar 2012 7:36pm
Just undo the nut and gently ease the remains of the arm off the spindle Mick
Post #113862 19th Mar 2012 7:49pm
Tried that John , for some reason the drivers side is stuck solid unlike when i had trouble with the passenger one a couple of gentle taps and it came off ... Thumbs Up
Post #113866 19th Mar 2012 7:52pm
There are a few different types of 'wiper arm removal tools' Thumbs Up
Post #113867 19th Mar 2012 7:54pm
Thumbs Up Better go looking then might need one for tomorrow …. Thumbs Up
Post #113868 19th Mar 2012 7:55pm
If you're needing it off urgently bring it down and I'll get it off Thumbs Up
Post #113870 19th Mar 2012 7:58pm
Will keep that in mind John , need to get a wiper arm first ... Laughing
Post #113878 19th Mar 2012 8:25pm
surely this is covered on the warranty mick.. ... - .- -.
Post #113880 19th Mar 2012 8:29pm
i never thought of that stan , you reckon ... Whistle
Post #113883 19th Mar 2012 8:33pm
simon1233
Mick, if you have a landrover warranty then this should be covered. Thumbs Up
Post #113889 19th Mar 2012 8:56pm
Deffo under warranty Mick Smile
For it to shear it means its been replaced and not tightened to the correct torque before though, or right on the splines themselves so eventually they slip off that tiny bit and by that time already worn away the groves on the arm enough.
its lucky they use a softer metal on the easier bit to replace! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113923 19th Mar 2012 11:45pm
SteveMFr
Site Sponsor
If you have an auto-glass shop close by, they should be able to help as well.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #113945 20th Mar 2012 7:17am
Land Rover calling out have been told its covered under warranty ... Thumbs Up
Post #113989 20th Mar 2012 10:59am
Well LR Assist could not fix it , maybe if he had a wiper arm puller it would have helped , anyhow had to take the car to the dealers which was called in via LR Assist …
Dropped it off and was given a Vogue SE 4.4 TDV8 as a replacement until mine is fixed ... Thumbs Up
Post #114027 20th Mar 2012 2:55pm
Should have been a 10minute job that Mick... what on earth do your local dealers do?? Test drive it and hope you like the new one enough to part ex it while its spent a few days having a wiper arm replaced???
Hows the 4.4 anyway Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #114087 20th Mar 2012 8:46pm
