![]() | Home > Maintenance & Mods (L322) > Intermitent sunroof |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Might need more info than it doesnt work. In one direction? Both? Closing? Discovery 4 HSE
TTF Member Since: 06 Feb 2012 Location: Wiltshire Posts: 130 ![]() ![]() ![]() |
Quite simply - does not work! Nothing at all, no noises, no motion, nothing! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35681 ![]() ![]() |
in the space of 22 minutes its gone from 'intermittent' to 'not working at all'......... |
Not really, if you read the first post I have said that sometimes it works perfectly, other times nothing at all. I was then asked what happened when it was not working and so I have said that it does not work at all - nothing happens. Therefore the issue is "intermittent", sometimes working, sometimes not at all. |
i understand now, when it doesn't work, it doesn't work at all....
Yes, I had found these. Sadly none really match the symptoms on mine but I may try the reset just in case! |
there is also a RAVE download link in the wiki....worth browsing through that.. ... - .- -.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Worth bearing in mind - it's a Range Rover.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
I think I heard it from a seller of pre-loved Range Rovers.... |
Even SWMBO smiled at that... And trust me, when cars come into a conversation her eyes roll backwards and her pulse stops!!! |
