Home > Maintenance & Mods (L322) > Intermitent sunroof
TTF
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Intermitent sunroof
RR 4.4 Vogue SE 2006 56 facelift model.
Sunroof does not work all the time, sometimes perfect, other times nothing at all! I have swapped the switch with another RR but to no avail, next is the relay. Any other thoughts/experiences out there?!
Post #114091 20th Mar 2012 9:20pm
Might need more info than it doesnt work. In one direction? Both? Closing? Discovery 4 HSE
1993 90 Tdi
Post #114094 20th Mar 2012 9:39pm
TTF
Quite simply - does not work! Nothing at all, no noises, no motion, nothing!
Post #114096 20th Mar 2012 9:42pm
in the space of 22 minutes its gone from 'intermittent' to 'not working at all'......... Shocked ... - .- -.
Post #114161 21st Mar 2012 8:49am
TTF
Not really, if you read the first post I have said that sometimes it works perfectly, other times nothing at all. I was then asked what happened when it was not working and so I have said that it does not work at all - nothing happens. Therefore the issue is "intermittent", sometimes working, sometimes not at all. Confused
Post #114162 21st Mar 2012 8:55am
i understand now, when it doesn't work, it doesn't work at all....
anyways, we have a search function from which i found this,
http://www.fullfatrr.com/forum/topic8993.html?highlight=sunroof
hope it helps.. ... - .- -.
Post #114164 21st Mar 2012 9:02am
TTF
Yes, I had found these. Sadly none really match the symptoms on mine but I may try the reset just in case!
Post #114165 21st Mar 2012 9:08am
there is also a RAVE download link in the wiki....worth browsing through that.. ... - .- -.
Post #114166 21st Mar 2012 9:19am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Worth bearing in mind - it's a Range Rover.
Although the electrics are Bosch, they still have the sainted presence of Joe Lucas (the Prince of Darkness) about them. Just because you feel it's time to open or close the sunroof means nothing. When the car is ready to open or close it, it will. Until then, be patient.
Post #114169 21st Mar 2012 9:32am
Laughing Laughing Laughing Simes, thats fab Laughing Laughing Laughing
Craig Bow down
Post #114170 21st Mar 2012 9:43am
Simes
I think I heard it from a seller of pre-loved Range Rovers....
Post #114173 21st Mar 2012 10:19am
Even SWMBO smiled at that... And trust me, when cars come into a conversation her eyes roll backwards and her pulse stops!!! Yawn
Craig Thumbs Up
Post #114177 21st Mar 2012 10:22am
