Home > Technical (L322) > removal of tpms
doug
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
removal of tpms
hi all
i changed the wheels on my rr ages ago,the annoying yellow light in the dash has finally gotten to me,i took the old wheels down to my local garage for the sensors to be fitted to the new wheels,the mechanic? said he couldn't take them off without breaking them,has anyone any idea how to do this as,it would give me great pleasure in handing them over for refitting?
do the sensors really have to go on same corners they came off?
the car is an 07 tdv8 vogue se if it makes any difference
thanks in advance ,any advice is much appreciated
Post #11125 15th Jan 2010 9:44pm
doug
does anyone have any idea? are they designed to break on removal?
Post #11299 20th Jan 2010 1:01am
daveo
hi, is the sensor not fitted via the valve hole, my brother had them on a ford he had, they are the same unit, and they were fitted through the valve and then a nut held them in place, two min job, but you need the tyre off to remove and fit. V8 facelift Range Rover Autobiography 22" wheels.
Post #11303 20th Jan 2010 9:27am
doug
hi,thanks for your reply
the sensor does sound the same,although on the inside there is no nut,the plastic sensor spins when turned via the nut on the outside and looks like breaking completely,tried wd40 on nut and holding in place but just scared of breaking
am i just being a big jessie or are there any more suggestions
Post #11329 20th Jan 2010 8:07pm
coko
2009 Range Rover Vogue TDV8 Bournville
I would have thought that it is a few minute job on the computer. Rolling Eyes
and as far as I am aware the sensor does not have to go back on the same corner where it came off - or at least it is not the case on my car as I keep changing the wheels around Confused
maybe ken will be able to shed more light into it. Wink
Post #11338 20th Jan 2010 9:03pm
The TPMS sensors seem to be EXTREMELY fragile and if the tyre fitter is a ham fisted idiot (like the ones at my supplying dealership) they will more than likely break them when replacing tyres. Discovery 4 HSE
1993 90 Tdi
Post #11422 22nd Jan 2010 6:45pm
