![]() | Home > Technical (L322) > Strange revving fault - Transmission / Electrics / ECU? |
| The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425
Welcome to the forum |
| ngb13 Member Since: 22 Jan 2010 Location: Cheshire Posts: 19
Thanks
I can only recommend that you call a transmission specialist but from what you have said it sounds like that could be the problem.
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
I had a not disimilar problem on my TD6 where it felt like the clutch was going (if it had a clutch, i.e then I thought it was the TC also)
| Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466
Got to agree it sounds like maybe a slipping clutch.
Thanks for the suggestions, here's a bit more info -
| speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727
1) could the s/c belt be slipping
| delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116
how many kilometers on the clock ?
Turns out it is the engine fan that I am hearing.
Thermostat done and seems to have cured the fan coming on when it shouldn't, however, it seems this fault wasn't connected to the HDC. Car is back in the delears for further investigation.
65k miles on the clock |
its been known that a not quite 100% battery can cause hdc and other electrical gremlins onto no6 Range Rover
New Bosch battery was the first thing I tried. |
the hdc is linked to the abs and the steering angle sensor have you had any faults with steering / repairs and have you turned the steering lock to lock while running to recal the steering angle sensor |
| All times are GMT |
