![]() | Home > Technical (L322) > IIDTool: FAULT CODES - EAS/air suspension/amp/speaker faults |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
As general info (happy already received a PM from engineer Patrick):
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1531
Thanks Steve.
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
I will be checking out my speaker errors very shortly too |
| DiREW0LF Member Since: 11 Feb 2012 Location: Northern NJ Posts: 8
Wow, I don't think they put enough wiring under the seat. |
That's the side with the BCM... |
RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
| tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283
Hi Steve
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3964
On a UK car it's worth noting that the wiring nest is under the passenger seat. Probably also worth mentioning that I have the two upper speakers in the rear doors not working but the wiring under the seats was OK. Need to look at the plugs on the amp etc but not quite sure where to start |
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
I constantly get 9A11 code coming up on mine - I clear it but it comes straight back, from above, it says its the front centre speaker.
Hi Tom, It sounds to me as if your compressor may be on it's last legs. I'll check more tomorrow, though.
Cheers Steve, let me know what you find.
| millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 341
Steve
Hi John,
Steve
| All times are GMT |
.jpg)
.jpg)
