![]() | Home > Technical (L322) > IIDTool: FAULT CODES - EAS/air suspension/amp/speaker faults |
As general info (happy already received a PM from engineer Patrick):
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1526 ![]() ![]() |
Thanks Steve.
I will be checking out my speaker errors very shortly too |
DiREW0LF Member Since: 11 Feb 2012 Location: Northern NJ Posts: 8 ![]() ![]() ![]() |
Wow, I don't think they put enough wiring under the seat. |
That's the side with the BCM... |
![]() ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
Hi Steve
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3917 ![]() ![]() ![]() |
On a UK car it's worth noting that the wiring nest is under the passenger seat. Probably also worth mentioning that I have the two upper speakers in the rear doors not working but the wiring under the seats was OK. Need to look at the plugs on the amp etc but not quite sure where to start |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I constantly get 9A11 code coming up on mine - I clear it but it comes straight back, from above, it says its the front centre speaker.
Hi Tom, It sounds to me as if your compressor may be on it's last legs. I'll check more tomorrow, though. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Cheers Steve, let me know what you find.
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Steve
Hi John,
Steve
