![]() | Home > Technical (L322) > solar power charger |
dave.s Member Since: 01 Nov 2011 Location: Isle of Wight Posts: 127 ![]() ![]() ![]() |
Hi all, going on a cruise in august for 2 weeks and will be leaving rr parked at docks.
http://www.fullfatrr.com/forum/topic3121.h...olar+panel
Cheers for reply, have been through search but not much about the watts. i.e is it worth
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
£9.99 at maplins... http://www.maplin.co.uk/solar-powered-12v-...rger-98358 ... - .- -.
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 ![]() ![]() ![]() |
can this be plugged into rear power socket with panel on
Cheers Stan, seen that one but there must be a differance in capability does the 1.5 watt do the job
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
I have a Ring 12v 2.4w solar maintainer. It works very well indeed.
Reformed and DavidP, thanks, thats what i wanted to know first hand experience
I have just ordered one as my FF often stands for a week without moving, is there a problem with them if they stand for a while ? Current Stable:
just picked up the maplin charger so thanks to all for your help
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1236 ![]() ![]() ![]() |
Just picked up a 2.4 watt one and have popped it in the rear side tinted window. Hopefully it will help keep the engine topped up as don't always do a long run to get the battery charged up. Tom
These solar chargers are all very well but if the diode in them fails, as they can, and they are still plugged into the car they effectively act as a resistive load on the battery and as a result slowly discharge it.
nicedayforit - that will be the reason that i don't leave mine connected and I cannot remember who suggested that I didn't. I only connect it when i'm away for more than 3 days. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
I have been running a Sunsei 4 watt one in another vehicle which gets infrequent use for the last 5 years - this is a good quality make. These type of solar chargers / the Maplin type etc will not recharge a flatt battery, they will maintain a battery and overcome natural discharge / battery discharge wastage, but thats it. |
