Home > LPG > LPG - MPG
Page 2 of 3 <123>
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Quote:
I got the biggest tank in mine, 102 litres, as I had your problem in the past. You need to fiddle about with the wheel well to make it fit but its worth it.
Interesting.
How much fiddling, and does the boot floor sit completely flat?
David
Post #120981 9th May 2012 11:48am
fisha
any suggestions on where to get a tank from? the best i've seen for a 95l tank is in the region of 400quid ... which is quite a lot for that extra few litres. V8 or else ...
Post #121063 9th May 2012 9:31pm
because of the nature of what the tank does [holds gas!!] , the best and safest place to buy one would be an authorised lpg dealer.. ... - .- -.
Post #121131 10th May 2012 12:08pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
if you dont get a tank from a ALPG Installer it may invalidate your insurance
i have a 90l tank in mine (max fills to 75l+)
i pay 74p pl atm should come soon due to summer months drop of about 4p off soon
i get easy 180 miles on daily short trips on good runs i get 230-250 this is from about 60-65l monitered over 4 year period
i am heavy footed
Post #121148 10th May 2012 1:01pm
paneldamage
Rads -
To get the boot floor panel to sit completely flat, I had to remove the spare wheel mounting - its a pressed piece spot welded to the floor of the well. I managed to remove the piece using a spot drill avoiding any damage to the well itself. Touched in with red lead after to be safe from rust. I placed some decent rubber blocks between the gas tank and the wheel well, to avoid vibration, before bolting it down.
I took most of the felt mat off the back of the boot floor panel as well. After that, it sits flat. On top of the boot floor, I have the thick rubber boot mat - no worries bout noise etc.
Gotta say, the LPG installer didnt do the best job of this aspect of the install - he left the panel proud of the floor- but it was easy to sort out as described above. No other worries with his work though.
Post #121254 10th May 2012 10:54pm
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
i get about 200 miles round town in mine but filling up all the time is a pain im going to upgrade my tank which is easy to do
i found some good tanks here
http://www.tinleytech.co.uk/acatalog/Tanks_-_4-hole.html
if you use your own pipes and fittings they are even cheeper
Post #121296 11th May 2012 9:48am
Hoveronly
United Kingdom 2006 Range Rover Vogue SE 4.4 V8 Zambezi Silver
Doesn't seem much point in having an LPG system if only used on the motorway. I cant tell when mine has switched itself on without looking.
Post #121673 14th May 2012 9:44am
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
I recently changed the spark plugs to NGK Iridium LPG plugs and the MPG seemed to fall from about 200 miles per tank to around 150-160! I've also had a front end 2010 conversion done recently, involving a new air filter, so I reckon the best thing is to get a decent remap which hopefully will restore some of the lost MPG. Local tuners charge £150 for a mobile but bespoke service ( not a chip swap). Worth a punt, as the short range is driving me mad!
Post #129883 8th Jul 2012 12:21am
Hoveronly
I was informed by a 'Chipping' company that they wouldn't remap an LPG converted car. Anyone any idea why that is?
Post #129884 8th Jul 2012 12:29am
SparkyPhil
England 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
I get 13/14 mpg local and 17/18 mpg on a run to Anglesey on dual(65/70mph) and single(40/60mph) carriageway roads.
Phil.
Post #142536 22nd Sep 2012 8:02pm
Tallsaj
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
LPG mpg
I just had my sc 55 plate range converted recently pain in the but to set up still not running good for some reason urban mpg I am only getting 120 miles max on 75 litres Crying or Very sad is this correct u think guys? I think I need to find some 1 who knows how to set it up properly it's a Brc plug n drive system fitted with 2 vapourisers.
Post #205546 25th Aug 2013 12:06am
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Something defo wrong there. A plug and drive SRC system should return 3 per litre not 1.6. What does it do to the gallon on petrol? Probably need restting on the gas base map.
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #205591 25th Aug 2013 10:21am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I get between 200 and 220 miles out of 80 litres on a SC with prins.
Post #205592 25th Aug 2013 10:22am
Tallsaj
Mpg
On petrol on £30 about 50 miles[/code]
Post #205625 25th Aug 2013 1:47pm
Jonno
That's only about 10.5 per gallon on petrol. It suggests the car wants looking at before you do the gas.
What's the mpg on a run? 5.0 supercharged autobiography
Post #205626 25th Aug 2013 1:52pm
Page 2 of 3 <123>
