![]() | Home > Maintenance & Mods (L322) > Drop links? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3987 ![]() ![]() ![]() |
No, they go either way up.
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Thanks for that I'll get it back together now |
Is it when turning 45-90 degrees? |
No it's all the time over ripples in the road, makes a kind of fast knocking noise, sounds like front passenger side suspension. Range Rover 4.4 V8 Vogue |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
I had the drop links and suspension bushes replaced which did not help. however after using Stevena's advise to loosen and tighten the compliance bush on the tie rod and all the other front suspension components the knocking disappeared. the car was as quiet as a very content mouse no noise nothing almost felt like I was driving a range rover
compliance bush on the tie rod? What is that> |
