Home > Maintenance & Mods (L322) > Drop links?
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Drop links?
I've just removed my front drop links to see if they are causing the knocking (both new OEM parts in last 6 months) they're both fine & have no play. I went for a drive without the anti-roll bar drop-links and it's still knocking, so that rules out the anti roll bar and drop links. Big Cry Question is do they have a right way up? Just something else to check while it's in bits Confused Range Rover 4.4 V8 Vogue
Post #121332 11th May 2012 5:56pm
No, they go either way up.
Have you checked the anti-roll bar bushes?
Post #121333 11th May 2012 6:08pm
Glideman
Thanks for that I'll get it back together now Very Happy I disconnected the anti roll bar drop links so the bushes should be fine as it's still knocking Confused Range Rover 4.4 V8 Vogue
Post #121334 11th May 2012 6:16pm
Is it when turning 45-90 degrees?
Post #121338 11th May 2012 6:49pm
Glideman
No it's all the time over ripples in the road, makes a kind of fast knocking noise, sounds like front passenger side suspension. Range Rover 4.4 V8 Vogue
Post #121339 11th May 2012 6:50pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
I had the drop links and suspension bushes replaced which did not help. however after using Stevena's advise to loosen and tighten the compliance bush on the tie rod and all the other front suspension components the knocking disappeared. the car was as quiet as a very content mouse no noise nothing almost felt like I was driving a range rover
but now its coming back Big Cry not as loud as before but still there
what else can it be Question
Post #121341 11th May 2012 6:58pm
Glideman
compliance bush on the tie rod? What is that> Confused Range Rover 4.4 V8 Vogue
Post #121350 11th May 2012 8:06pm
