Home > Technical (L322) > Driver seat and steering column problem
saxrom
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Any body come across this problem before i have a 2003 4.4 vogue and the drivers seat and steering column both stop working at the same time.
I have tried the pasenger seat and all is fine there its just the drivers seat and the steering adjustment.
Post #12135 1st Feb 2010 10:30am
Cannot find anything relating to your seat is it possibe that you have accidentally unplugged the connector under the seat.............
Steering wheel
http://www.rangerovers.net/repairdetails/steering/tilt3.html Thumbs Up ====================================
Post #12137 1st Feb 2010 11:44am
saxrom
Cheers Mick I have looked under the seat can't see any loose connections it's strange that the seat and steering adjust pack up together it's an intermittent fault but lately they have stopped working full stop.
Post #12152 1st Feb 2010 4:19pm
Do your mirrors work .......... ====================================
Post #12154 1st Feb 2010 4:29pm
saxrom
Yea they work ok
Post #12155 1st Feb 2010 4:37pm
Try this Self Test .......
Vehicle in Park and driver door open
Hit the seat memory buttom five times
then 2-1-1-2 using the memory preset buttons 1 and 2.
should make seats and mirrors go through complete movments. if motor did not operate at all its a motor or faulty wiring, If suddenly stops loss of feedback position is happening and you can use the test procedures in manual. ====================================
Post #12156 1st Feb 2010 4:41pm
saxrom
Just tried the test nothing happened
Post #12157 1st Feb 2010 4:49pm
Only other thing i can think of is the ECU ........ ====================================
Post #12158 1st Feb 2010 4:56pm
saxrom
Ouch cheers Mick one thing do you know if they both run off the same fuse and if so where it is located.
Post #12159 1st Feb 2010 5:01pm
saxrom
Post #12160 1st Feb 2010 5:10pm
Found this regarding seat faults.........
SYMPTOMS
Driver's seat does not move but mirrors continue to work ok.
Mirrors no longer function but driver's seat moves ok.
DIAGNOSTIC CHECKLIST
If both seat AND mirrors stop functioning without warning check for blown fuse or other electrical supply problems before condemning ECU.
Don't forget - seat only moves when park selected on gearbox! ====================================
Post #12161 1st Feb 2010 5:13pm
will check to see where fuse is not sure if it's in the fuse box in the boot or in fuse box in the glove box ====================================
Post #12162 1st Feb 2010 5:16pm
saxrom
Cheers for your help Mick
Post #12163 1st Feb 2010 5:28pm
Vogue
not on mine it doesn't. Mine moves the seat all the time and has done so since it was new.
The only thing mine does is I have to keep my fingers on the preset buttons if using the memory and the g/b is in drive. If Park is selected I only have to hit the memory button once and the seats return automatically to their saved settings.
seems to be quite a few variations on the theme...
Post #12164 1st Feb 2010 5:34pm
Still looking not had a chance yet Saxrom ......... or if anyone else knows would be helpfull ====================================
Post #12177 1st Feb 2010 7:38pm
