![]() | Home > Technical (L322) > can suspension compressor be stripped/repaired? |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 ![]() ![]() ![]() |
Just to reignite this thread again, I was in my local Stratstone (Newcastle) today enquiring about a new air compressor unit.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
have you got the headlight switch on auto, if so could it be a faulty switch/relay causing this..just a thought.. ... - .- -.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
It could be - also could be the bulbs or ballasts on their way out. The bay of fleas is OK for bulbs and ballasts. |
@Stan I don't have auto lights. Its my 2004.
ok bob, i assume you have checked the connections/plugs in the light units.. ... - .- -.
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
Thanks guys for this thread,
Stan the flickering moves from one side to the other, but last night driving home from work the were both flickering.
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Hallo from germany, I sell brandnew repair-kits for the WABCO unit..., look at ebay.co.uk, look for: EAS Range, then you see my offer..., kind regards from germany! Uli |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Have had this quite a few times on customer cars,,, Not too expensive either, if i remember correctly they are under £40... Craig ![]() |
Sorry, but all the parts are not for "under 40 GBP", because there is not only a pistonring..., it is incl new dryer, cylinder and pistonring, also new rubber o-rings..., if it costs under 40 GBP, I will order for germany 10 repair-kits |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Here is a direct link to Meerbusch's offer on eBay ( I sifted through all the P38A stuff, of which there is a lot!!)
@ Cam-Tech-Craig, sorry, of course you write about the little switch at the boiler under the right side of the RR, I had buied a new example here in germany for 50 €, but it didn,t help in my problem, therefore I "engeneered" the repair-set, and...
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
If its £190, why isn't there a buy it now option? It's an auction with a starting bid of £1 with no reserve. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
.. therefore you can send an E-Mail, and you can pay with PayPal to my E-Mail-adress, than I will send the package... |
