Home > Technical (L322) > can suspension compressor be stripped/repaired?
Page 2 of 5 <12345>
fisha
I'm not saying that my error = your error , just that what the error code reads is only an indicator of what to diagnose
The sensor screws into the rear of the air tank ( opposite end of the valve block ) under the sill. The manuals say the sensor is non-replaceable ( need whole new tank ) , but there is a seperate part number for it, and it just screws in.
For my fault, it would disable the air susp, and maintain normal ride height by bypassing the tank and inflating the airbags directly. I couldn't select heights though - it locked itself to normal. The bags have no leaks, and the pump only ran to topup / make adjustments. Now its fixed, I dont notice that the pump is running significantly more or less. The tank is filled up, it tops up air bags from the tank, then tops up the tank.
47p2 is correct in that if the system thinks its taking too long to fill, it'll throw errors as well.
Although from experience, if the pump is filling the air bag directly - its much slower to lift up than if its filling from the tank.
Couple of thoughts/questions sping to mind:
- is the pump running regularly to make top ups? ( to cover a possible leak )
- are you using the access height alot? ( from access height to off road may be more than a tank full to acheive - so its defaulting to the pump direct to air bag = slow ) V8 or else ...
Post #89071 26th Oct 2011 10:35pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Just to reignite this thread again, I was in my local Stratstone (Newcastle) today enquiring about a new air compressor unit.
I asked if there were any kits to refit the unit myself and was told that if I had a VIN starting 5A up over then there is a refit kit.
Im hoping my problem will be sorted if I fit a new battery because Im also getting my main lights flickering at night. Can anyone advise me about my lights ie could it be a battery problem?
Cheers Grant Thumbs Up
Post #114319 22nd Mar 2012 12:25am
have you got the headlight switch on auto, if so could it be a faulty switch/relay causing this..just a thought.. ... - .- -.
Post #114332 22nd Mar 2012 9:09am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
It could be - also could be the bulbs or ballasts on their way out. The bay of fleas is OK for bulbs and ballasts.
Post #114345 22nd Mar 2012 9:51am
Bob the B
@Stan I don't have auto lights. Its my 2004.
@Simes I am going to try the battery first as the lights have been flickering for over 6 months. Could do with a new one anyway coz its a bit hesitant to start on the really cold morning we've had.
Post #114350 22nd Mar 2012 10:15am
ok bob, i assume you have checked the connections/plugs in the light units.. ... - .- -.
Post #114352 22nd Mar 2012 10:35am
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Thanks guys for this thread,
The info is priceless, I'm just hoping I don't need to use any of it lol
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #114367 22nd Mar 2012 11:27am
Bob the B
Stan the flickering moves from one side to the other, but last night driving home from work the were both flickering.
Fitted new battery today so I'll see what happens tonight.
On the original subject my air suspension seems more responsive now and going into offroad mode a bit quicker but I'll have to keep an eye on it Thumbs Up
Just an update my lights were still flickering on the way home tonight but my suspension is def more responsive with the new battery Very Happy
Post #114413 22nd Mar 2012 5:47pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hallo from germany, I sell brandnew repair-kits for the WABCO unit..., look at ebay.co.uk, look for: EAS Range, then you see my offer..., kind regards from germany! Uli
Post #122988 22nd May 2012 5:51am
fisha wrote:
Quote:
Started getting a regular "air susp inactive" on the dash and it reads as pressure static when filling so i am guessing my compressor is getting tired.
Not necessarily.
Mine used to fault with this error from time to time, yet it still managed to keep the car at normal height for 1000's of miles. The problem was actually the pressure sensor itself on the tank. It wasn't registering an increase in pressure when the system started up and did a pressure test.
The pump itself was fine and managed to pump the air bags directly. Just the sensor duff.
Have had this quite a few times on customer cars,,, Not too expensive either, if i remember correctly they are under £40...
Craig Thumbs Up
Post #122996 22nd May 2012 8:07am
Meerbusch
Sorry, but all the parts are not for "under 40 GBP", because there is not only a pistonring..., it is incl new dryer, cylinder and pistonring, also new rubber o-rings..., if it costs under 40 GBP, I will order for germany 10 repair-kits Wink)
Post #123014 22nd May 2012 10:19am
Here is a direct link to Meerbusch's offer on eBay ( I sifted through all the P38A stuff, of which there is a lot!!)
http://www.ebay.co.uk/itm/Range-Rover-LM-3...2c658520c8
I think Craig was referring to the air tank repair, not the compressor ? .
Post #123024 22nd May 2012 12:42pm
Meerbusch
@ Cam-Tech-Craig, sorry, of course you write about the little switch at the boiler under the right side of the RR, I had buied a new example here in germany for 50 €, but it didn,t help in my problem, therefore I "engeneered" the repair-set, and...
@ Joe, THANKS for the link in ebay, of course it is not to buy for 1 GBP, only in the immidiatly-buy for 190 GBP incl. shippingcosts to GB or europe.
very interest forum here, I read a lot (95%) of good articles, but also some nonsens (5%) about the common problem with the batterie...
regards from Meerbusch near Düsseldorf! Uli
Post #123026 22nd May 2012 12:57pm
Andy
If its £190, why isn't there a buy it now option? It's an auction with a starting bid of £1 with no reserve. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #123294 23rd May 2012 7:59pm
Meerbusch
.. therefore you can send an E-Mail, and you can pay with PayPal to my E-Mail-adress, than I will send the package...
Post #123301 23rd May 2012 8:28pm
Page 2 of 5 <12345>
