Home > In Car Electronics (L322) > Ipod install.... Easy?
Hi Chaps and Chapettes,
Has anyone installed a LR ipod kit to a 2008 model ff.
Dan has given me a good quote and was wondering how hard it is for some one who probably has more confidence tham talent with the spanners. I have seen the instructions and it looks like a dash apart job. How hard is it?
Any advice will help.
Cheers There is nothing that can't be fixed with a hammer😜😜
Post #122685 19th May 2012 8:19pm
SteveMFr
Site Sponsor
Take a look at these vids:
&list=PL063C3AB14BE6984C&index=59&feature=plpp_video
and
&list=PL063C3AB14BE6984C&index=55&feature=plpp_video
The most difficult bit of the whole job is removing the vents in the dash end caps (around 1:30 in the first vid). He makes it look easy because - I suspect - he's bent the locking tabs inward to where they don't spring into place anymore on their own. If you do this, your vents won't sit tightly anymore (the 'art' in a job like this is not actually getting it done but getting it done in an OEM fashion so that you don't have squeaks or rattles afterwards). So to remove the vents, you have to find appropriately sized screwdrivers and try to work the 4 clips while simultaneously pulling the vent = fiddly.
Everything else should be easy. That said, there was a post recently where a dash pad had been reinstalled w/o being hooked into place and the hooks were resting on their slits causing the pad to bulge (you'll see).
Just pay attention to what you are doing and how each piece fits. You'll get through it.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #122829 21st May 2012 9:43am
supershuttle
NMJones,
2008 yours will be like mine (2007) so if you do it, write it up or better get the camera out and share. I need to get the screen out for a bit of Carbon wrapping so a heads up on any pitfalls would be welcome. Thumbs Up
Obviously if I get stuck in first I'll do the same. Very Happy Geoff
Post #122883 21st May 2012 2:25pm
Saw MJDronfields post about his dash, all back together i think now. Might have a go.
Though I have been quoted £60 to install the kit if i supply (seems too cheap) by mobile solutions in derby. Doubt they can do it for that though. Probably at least 2hrs in it i should think if all tools present and correct. There is nothing that can't be fixed with a hammer😜😜
Post #122948 21st May 2012 6:58pm
Stephen.Gazard
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
I've done mine and also did it on the RR Sport ..... fiddly but if you take your time and are methodical it is perfectly feasible.
Took me about 1 hour 1/2 from memory
As stated above .... biggest challenge is getting the vents out without breaking .... Stephen Gazard
Range Rover L405 LWB SVA Overfinch / Bespoke
Maserati GT 2017
Maserati Levante Trofeo
Mercedes SL63 AMG
Mercedes S500L
Post #122963 21st May 2012 9:31pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Can someone who has fitted this kit please post photos of the connectors etc AFTER fitting. I fancy the kit, but can't see where the phone needs to be etc? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #122970 21st May 2012 10:45pm
With the genuine ipod kit, does it retain Changer function or do you have to lose that? Does anyone know?
Cheers. There is nothing that can't be fixed with a hammer😜😜
Post #123080 22nd May 2012 7:56pm
Cheers.
You keep them both but with a switch in the glovebox to change between the iPod and changer...
Craig Thumbs Up
Post #123081 22nd May 2012 8:02pm
Cheers Craig. There is nothing that can't be fixed with a hammer😜😜
Post #123084 22nd May 2012 8:10pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
What's the damage for the kit then??
Post #123107 22nd May 2012 8:51pm
http://www.fullfatrr.com/forum/topic11618.html
Post #123117 22nd May 2012 9:25pm
