![]() | Home > General > range rover ? |
| Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181
I've just switched from a Touareg to a Range. I was running a 3.0tdi VW and getting about 26-27mpg out of it. So far the Range is doing about the same. I reckon a remapped TDV8 might get close to 30mpg but you say you are wanting to release a chunk of cash so not sure if your budget is set at TDV8 level (24k+).
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Buying advice
| Skinnyrunt23 Member Since: 20 May 2012 Location: Leeds Posts: 14 |
my vw will probably sell around the 20k mark, its a bluemotion one so it should get around that. Plan is to free up about 5k for a caravan, so looking around 15k mark.
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927
you should get a quality sequential system now adays for £2k, the only thing is you won't get 120l tank in a FFRR unless you take up boot space. the normal thing is to use the spare wheel well with a donut tank. you could try that in conjunction with smaller cylinders mounted underneath and a custom made smaller petrol tank. maybe someone with an LPG conversion will let you know what kind of tank/tanks they have fitted.
Thanks for the advice, makes a lot of sense. I was going down the lpg route only because of cost. From my searches so far not seeing any decent tdv6 for that kind of money .
would you say a range rover is more to maintain than a vw toureg? |
Yep |
| Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267
Depends on where you go and if you're prepared to get your hands dirty.
With all due respect, what quality are the discs and pads at that price my friend? We have had some really crappy cheap brakes causing all manor of problems with customers cars... Usually fitted by shifty car dealers when selling... Craig |
I've no idea about those as they were just marked as "Aftermarket".
| nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 233
I ventured into FFRR territory late last year - bought a 2005 Vogue 4.4 with the intention of a) converting to LPG and b) getting a 2010 conversion done. My initial ownership experience was about as bad as it could get - the car I found was on the face of it excellent value, with a full dealer SH and only 52000 miles, free 1 year warranty included in sale. However, after driving it home (before I actually got home in fact) the gearbox failed! |
Does the Range cost more to maintain than the Touareg....?
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
As above I've run a car long term, 30k+ on LPG and am now a diesel person.
guess you get good and bad cars regardless. I love the look of a FFRR. Not sure abot bio D, isnt it hard to come by? how much? |
| All times are GMT |
