![]() | Home > Technical (L322) > Can't Turn Ignition Key - Any Ideas?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35850 ![]() ![]() |
this http://www.fullfatrr.com/wiki/Key_stuck_in_ignition is for a stuck key but it might help... ... - .- -.
luckyrobp Member Since: 02 Apr 2012 Location: brigg Posts: 7 ![]() ![]() ![]() |
I called the AA in the end, and the battery only showed 4 volts on the tester. he put the jump leads on and all came to life again, so I was very lucky.
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
Thanks for the advice, I shall have another look around. No-ones been messing with the glovebox, and I can hear some clicks from the steering column when I drop the key in, so think there is power to the coil thingy! The key is still only turning about 10degrees.
Perhaps the gearbox interlock is causing an issue? Land Rover Addict
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6430 ![]() ![]() |
Do you feel the cable lock the key in the ignition when you turn it 10 degrees, or can you still remove it? Are you in accessory mode when turned to 10 degrees or no power?
You couldn't remove it, but it wasn't getting as far as accessory mode.
Any chance it could be a build up of crap in the barrel not allowing the key to enter fully? |
I don't think so - a sticky cable feels more likely....
