![]() | Home > Technical (L322) > ride height |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Could be that....(maybe your brothers needs resetting!) or
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35783 ![]() ![]() |
access/standard height ?
Your brother secretly owns an IIDTool or EASControl...
or RAC |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
When I picked mine up, I noted it was sitting lower and the ride not so supple....
igore Member Since: 20 Oct 2010 Location: portsmouth Posts: 118 ![]() ![]() ![]() |
cheers chaps for your comments |
waiting for brother to come round next i think his is on 19s and mine are 20s ONE LIFE LIVE IT |
After doing my Rover All Comms recalibration I appear to be @ 800mm all round (on 20" rims). Is there a standard measurement we can verify against? .
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Someone correct me if I'm wrong . But diameter of tyres should be the same for 18-19-20" rims so ride height would be the same regardless of rim size
My Calibration was carried out by Land Rover....I run on 19" rims with 255/50R19 boots....
chaps i measured from centre of wheel to the wheel arch and got 490mm all round this just dont seem right.
OK, so if you read the references above once more I think you should be measuring to the BOTTOM of the wheel rim, not the centre. This would add about half a wheel diameter, so 9.5" (about 240mm) to your 490mm, thus giving you 730mm.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
No you're not missing anything, you are right, the wheel rim dia will mean the wheel arch to the bottom of the rim measurement will vary according to which wheel is fitted.
