Home > Technical (L322) > Intermittent wipe
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
Intermittent wipe
Hi all, got a problem with the wipers, when using the wipers on intermittent they do one sweep as normal then go straight on to the second speed, any ideas Confused gone fishin'
Post #126194 14th Jun 2012 6:04pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Do you have Rain Sensing wipers?...as these oftentimes have a mind of their own!!
Post #126321 15th Jun 2012 11:32am
my ones are rain sensing so on intermittent , they wipe when rain is sensed but you can adjust the duration between wipes .. ... - .- -.
Post #126324 15th Jun 2012 11:50am
Saint.v8
Is it duration that changes or sensitivity to amount of rain...??
Post #126326 15th Jun 2012 12:04pm
pretty sure its the duration cos if it buckets down the wipers work all the time.. ... - .- -.
Post #126332 15th Jun 2012 12:35pm
extract from the owners manual..
Post #126333 15th Jun 2012 12:40pm
Saint.v8
So the control changes the sensitivity of the sensor...not the duration of time inbetween wipes....
Post #126349 15th Jun 2012 3:01pm
mjdronfield
To be fair, I can't see the difference, if I increase the sensitivity, it will wipe more often, hence shortening the duration of the intermittent gaps.
Though if there is no rain, it just doesn't wipe, so the rain sensor system is much better to my mind.
Obviously I understand the difference in how the systems work, its just the terminology..................
I like it on mine.
Just a pity you have to move the lever down and back up, each time you start the car.
What bad design is that ?? !! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #126355 15th Jun 2012 3:18pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
2010 can be left on, and on a nice icy morning - say goodbye to your window rubbers Sad
*or* in a car wash with your engine running - say goodbye to your wipers ...
It's not a bad design, it's a GOOD design, because people forget to turn automatic things OFF Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #126358 15th Jun 2012 3:27pm
mjdronfield
Good point - I stoop corrected.
Didn't think of that.......... Thumbs Up
I unreservedly retract my statement about bad design.
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #126363 15th Jun 2012 4:09pm
andyboy
Hi, yes i do have rain sensing wipers and they do seem to have a mind of their own.
thanks guys you learn something every day Bow down gone fishin'
Post #126432 16th Jun 2012 10:28am
