![]() | Home > Technical (L322) > Fuel Inject. System error message |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Have you had it on diagnostics to see if there is a fault code logged??
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35677 ![]() ![]() |
fuel injector problem ?...like said above , you need to get a fault code .. ... - .- -.
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
Not got around to it yet although that's the obvious thing to do.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
normally either injector or fuel pump. |
Maybe your pumps are going, have they ever been changed. You can see on the forum several issues with the fuel pumps slowly going bad and failing. Maybe on yours the ECU detects low pressure build up and faults it. Best is to get a faultcode reading done to have a better idea. Good luck. MY 2010 5.0 SC Galway green and sand interior!!
mightymatt Member Since: 09 Jan 2014 Location: United Kingdom Posts: 2 ![]() ![]() ![]() |
I had the same issue ("Fuel Injection System" message, limiting torque and engine cutting out at speed) and wanted to report the fix. The garage did an injector leak back test to check all injectors were firing as expected. Turns out that two of them were leaking so I had these replaced for £185 x 2 (exc VAT) and charged £120 for the labour to diagnose a fit. All went well for a couple of weeks and on a long run I put my foot down and the "Fuel Injection System" was thrown again.
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
I've just been through all this mate. To start it was the low pressure pump then a week or two later the lift pump in the tank packed up!!!
Yes it is the gift that keeps on giving hey!? Had the fuel filter done a month ago during the annual service. What reg is you Rangey? Mines a 2003. |
2002 mate. My tank needs cleaned out as there's crap in the bottom of it. |
