![]() | Home > Maintenance & Mods (L322) > TD6 - Pros & Cons - CRTD2 Diesel Tuning Box |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6420 ![]() ![]() |
Fit one of these instead of a remap ?
enumbers Member Since: 12 Dec 2011 Location: South east Posts: 26 ![]() ![]() ![]() |
I would also be interested in any feedback on this unit could do with a bit more go |
I would say thats a variable resistor type unit once all the gubbins are apart...
Is that from experience kingpleb ? What does the "variable resistor" do ?
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
A tuning box can never match a true remap. Tuning boxes fool the ECU and engine into operating different to what each other "thinks" - i.e. it's a box which modifies signals going both ways to trick them.
and there is the rub.... what other engine parameters are required? why wouldn't it be a good idea? (to inject less/more fuel, etc) A remap does this too ? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Ie if the exhaust temps were getting high as the fuel was too lean(extremely common in pet told) the tuning box would likely not be able to correct for this.
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
I run a tuning box after i fitted i to my last turbo diesel (not a landrover) and was pleased with the results which were about a 3/4 mpg increase and a noticable increase in performance. However i find it makes the td6 quite noisy i probably get a few more mpg and it does seem to pick up quicker but cant say i am 100% pleased. As previous posts and after a bit of internet research all the tuning boxes do is up the pressure on the fuel rail so you effectively over fuel the engine some have other features but they all work the same way. There is a good guide on ebay of all places! Mine was a blue one! |
After extra mpg and smoother drive (better pick up) so a bit of both but mainly economy.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7929 ![]() ![]() ![]() |
A remap would also take into account turbo boost pressures, temperatures etc etc, just like the original map. In fact, it is the original "3d"map, but modified extensively.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Hi Joe
Anyone got any experience of re mappers in southern or northern Ireland 2004 td6 Adriatic Blue |
Fuel temperatures, boost pressure, engine temperature, driver driver, inlet air temperature, charge temperature, gearbox gear, gearbox temperature, EGR state... [etc] A remap does increase fuelling, but by altering the maps which are read as a result of looking at all these other parameters FIRST. A tuning box lets the ECU work out where it should be operating, and then just bungs some on top. |
Check prices and compare, but strictly going by what I've read about him, I'd go with Pete Bell. The added advantage is that he takes your map and modifies it vs. the generic map supplied by rapidremap. And to answer your question from above as to why a remap is better: in essence, a power remap adds fuel. So you can achieve the same through various methods - the most simple of which is adding a resistor to the wire from the coolant temp sensor so that the ECU always thinks the motor is colder than it is (=runs richer). This is more or less what a tuning box does - which is quite primitive. Properly done, a remap looks at all the same parameters as the DDE ECU - from throttle position to ambient air temp to air flow, etc. A tuning box throws a bucket of extra fuel in, a generic map takes what should be the proper additional amount at the right time and injects it, and a custom map such as from Bell is exactly the amount of fuel needed for extra performance or better mileage. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
