![]() | Home > Maintenance & Mods (L322) > Where to get TD6 gearbox oil? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Here's a good thread on this:
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Perfect! I knew I'd read it somewhere. I've a mate works for Castrol as well, so I'll hopefully have a chat with him this afternoon and see if they do an equivalent - or better - product. And naturally, see if he can do me a deal! Some of the BMW forums suggest that 7045E isn't actually all that special and there are better products out there. I shall report back. |
Stick with Texamatic 7045E |
I spoke to my 'oil man' who was of the opinion that yeah, 7045E wasn't anything amazing and that any Dextron III ATF would work just fine. He recommended Castrol Transmax Dextron III Multi-Vehicle, but also said he'd have a proper good look at the properties of 7045E just in case there really was a special reason to use it. |
Personally I would not put anything else but the correct fluid in. Why save a few pounds on fluid and then have to spend £2k on a rebuild |
I'm not basing any decision purely on budget - I agree saving £20 to end up with a £2k bill later on is the sort of folly practised by accounting departments the world over, but if there's a better alternative available, why not use it? Although I can only find Transmax Dex III in one litre bottles, so 20 litres of it will be £200. I'll stick with Texamatic for now! |
It is the same with the transfer case oil, which was specifically formulated for the NV225 unit. This is also pricy at @ £10 a litre (fortunately only one litre is needed), but it is not worth using anything else.
All interesting reading, thanks. I've an understanding of tribology - essential as part of my job - and after comparing the TDSs for both 7045E and Transmax Dex III I can see very little difference in the two, with the Transmax being mildly superior. But at £10 a litre it's not superior enough.
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
If your going to use Castrol insteas of Texaco it should be Castrol Dextron VI. Not Dextrom III as this has been superseaded.
Bought 20 litres of Texamatic. Found this:
And I've found a genuine one for nearly half that after googling the part number:
Where did you get that from? I've googled the part number and stuck it in eBay but can't find it anywhere. What I can find is the datasheet and I can't see any difference between that and ATF with the exception of the colour... ![]() |
The link to the datasheet is here:
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 ![]() ![]() ![]() |
Have you had a reply misteralz? |
