Home > Maintenance & Mods (L322) > Squeaky Rear Suspension |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7640 |
I've done a bit of a search, and guess that as my car sounds like an old pram (quote from another thread - made me laugh), from the rear, that the rear suspension bushes are at fault.
23rd Jun 2012 3:09pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Folks have had success with WD40/silicone lubricant etc, it is getting it into the right place that is the hard part, using syringes with needles etc to force the lubricant into the bushes.
23rd Jun 2012 3:50pm |
Blinkinlights Member Since: 29 Feb 2012 Location: Edmonton, Alberta Posts: 42 |
I was talking with a four-wheeler buddy of mine who suggested replacing the bolts with ones that have zerk fittings on them. It seems that the industry has come up with a possible sollution and they are used in extreme conditions. Does anyone know the size of the bolts that are used with these bushings? 2006 HSE |
24th Jun 2012 5:05pm |
I had to look it up. A zerk bolt has a grease nipple at one end so you can grease the mating face of the bush in situ. Which is nice. .
24th Jun 2012 5:52pm |
Second question is about the bushings and the control arms. Are they both aluminum or steel, and is there a problem with dissimilar metals? 2006 HSE |
25th Jun 2012 2:19am |
They are all steel as far as I know |
25th Jun 2012 6:55am |
Sort of going back on what I said at the beginning, I was planning on changing like for like, with genuine Land Rover bushes, but if they are a bit prone for doing this, are the polybush ones the way to go ?
25th Jun 2012 9:27am |
As far as I know there are no poly bushes available for the FFRR as yet, plus poly bushes will not give as much comfort as original bushes. Stick with original as they will outlast the time you own the vehicle |
25th Jun 2012 9:35am |
Famous Four do a complete polybush kit for front and rear;
25th Jun 2012 9:50am |
@ 47p2
25th Jun 2012 10:20am |
No pictures Joe but here is an excellent write up on the Saab forum showing the procedure and the FFRR is similar. Remember to get a new circlip for the bottom bush when changing it |
25th Jun 2012 12:27pm |
Thanks 47p2
25th Jun 2012 1:14pm |
The bushes will be as tight as getting a fiver out of Stan's wallet...well maybe not that tight. I used a 5' steel bar and a 7lb hammer to break the rust seal before attempting to pull them through |
25th Jun 2012 2:05pm |
Just got back from the garage, and apparantly there is excessive play in both rear lower hub bushes........
28th Jun 2012 1:39pm |
