![]() | Home > Maintenance & Mods (L322) > Squeaky Rear Suspension |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I've done a bit of a search, and guess that as my car sounds like an old pram (quote from another thread - made me laugh), from the rear, that the rear suspension bushes are at fault.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Folks have had success with WD40/silicone lubricant etc, it is getting it into the right place that is the hard part, using syringes with needles etc to force the lubricant into the bushes.
| Blinkinlights Member Since: 29 Feb 2012 Location: Edmonton, Alberta Posts: 42
I was talking with a four-wheeler buddy of mine who suggested replacing the bolts with ones that have zerk fittings on them. It seems that the industry has come up with a possible sollution and they are used in extreme conditions. Does anyone know the size of the bolts that are used with these bushings? 2006 HSE |
I had to look it up. A zerk bolt has a grease nipple at one end so you can grease the mating face of the bush in situ. Which is nice. .
Second question is about the bushings and the control arms. Are they both aluminum or steel, and is there a problem with dissimilar metals? 2006 HSE |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
They are all steel as far as I know |
Sort of going back on what I said at the beginning, I was planning on changing like for like, with genuine Land Rover bushes, but if they are a bit prone for doing this, are the polybush ones the way to go ?
As far as I know there are no poly bushes available for the FFRR as yet, plus poly bushes will not give as much comfort as original bushes. Stick with original as they will outlast the time you own the vehicle |
Famous Four do a complete polybush kit for front and rear;
@ 47p2
No pictures Joe but here is an excellent write up on the Saab forum showing the procedure and the FFRR is similar. Remember to get a new circlip for the bottom bush when changing it |
Thanks 47p2
The bushes will be as tight as getting a fiver out of Stan's wallet...well maybe not that tight. I used a 5' steel bar and a 7lb hammer to break the rust seal before attempting to pull them through |
Just got back from the garage, and apparantly there is excessive play in both rear lower hub bushes........
| All times are GMT |
